ek b18 key stuck??
Old Mar 22, 2005 | 12:54 PM
trez2k3's Avatar
Default ek b18 key stuck??
Hey I test drove a ek with a b18 swap the other day that I might buy. But when the ignition switch is in the 0 position it is very hard to turn the key. It has to be placed just right (kind of like a old nintendo cartridge lol). But it can be very frustrating. To replace the ignition switch can i just buy a 65 dollar replacement for a 96 civic or would i need one from an integra ls (which the b18 came from) or do i need the whole ignition assembly? Any help is appreciated, I really like the car except for this. thx
Old Mar 22, 2005 | 01:15 PM
AutoXer's Avatar
Default Re: ek b18 key stuck?? (trez2k3)
It may be the key cylinder or key is worn. Is there another key you can try? If it's the lock cylinder, it can be rebuilt pretty cheaply.
Old Mar 22, 2005 | 02:49 PM
trez2k3's Avatar
Whats the difference between the lock cylinder and the ignition switch? Is the lock cylinder the physical key hole?
Old Mar 22, 2005 | 03:42 PM
AllMotorHB's Avatar
Default Re: (trez2k3)
you having a b18 has nothing to do with the ignition switch. I have a 98 civic and their was a recall on the ignition switch. i'm not sure what other year civics had the recall as well but you can look into that.
Old Mar 22, 2005 | 05:17 PM
trez2k3's Avatar
re:you having a b18 has nothing to do with the ignition switch. I didnt think so but it was weird because the key said acura on it so i wasnt sure. But is the lock cylinder my problem with the key not wanting to turn or is it the switch?
Old Mar 24, 2005 | 07:47 AM
trez2k3's Avatar
Anyone have any idea??
Old Mar 24, 2005 | 07:51 AM
cherroneballs's Avatar
my ek key fits my buddys 92 integra with the same problem but I can get the doors open and start it. I just have to work the key right.
Old Mar 24, 2005 | 07:54 AM
IHateJDM's Avatar
Default Re: (cherroneballs)
it probably is your problem. they wear out. in my del sol, i can take the key in and out of the ignition while the car runs.
Old Mar 24, 2005 | 09:01 AM
trez2k3's Avatar
So should I go to honda and try to get a new key?
Old Mar 25, 2005 | 08:55 AM
trez2k3's Avatar
Any help??
Old Mar 25, 2005 | 06:33 PM
trez2k3's Avatar
Nobody?
fazalabbas
Jan 5, 2019 10:36 PM
romerosi
Feb 26, 2009 04:35 PM
boost fed ls
Jan 4, 2009 09:43 AM
