!!!!!!!!!Transmission Fluid!!!!!!!!!!!?
Old Mar 22, 2005 | 12:54 PM
the niz jiz's Avatar
Default !!!!!!!!!Transmission Fluid!!!!!!!!!!!?
im switchin the axles on my a 90 civic 4dr lx (Auto) we just took the axle from the pass side and a **** load of transmission, or some fluid came poorin out....is that normal, if its transmission fluid just refill it??? need help asap
Old Mar 22, 2005 | 01:01 PM
Gearspeed-Performance's Avatar
Default Re: !!!!!!!!!Transmission Fluid!!!!!!!!!!!? (N.O.R.E)
You should have drained the trans first
Old Mar 22, 2005 | 01:05 PM
turbohappy's Avatar
LOL, you're supposed to drain the tranny before you pull out the axles
Old Mar 22, 2005 | 01:24 PM
EP3_05's Avatar
Default Re: !!!!!!!!!Transmission Fluid!!!!!!!!!!!? (turbohappy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbohappy &raquo;</TD></TR><TR><TD CLASS="quote">LOL, you're supposed to drain the tranny before you pull out the axles </TD></TR></TABLE>
Yup, I learned this lesson a long time ago when I decided to work on my car without a manual....
Old Mar 22, 2005 | 01:35 PM
Default Re: !!!!!!!!!Transmission Fluid!!!!!!!!!!!? (91civic)
lol yeah iight thanks....well i got it on next time i'll drain it
Old Mar 22, 2005 | 02:02 PM
4drEF's Avatar
Keyboard Humorist
Default Re: !!!!!!!!!Transmission Fluid!!!!!!!!!!!? (GearSpeedEF9)
Hmmm. On a manual tranny car that is on a flat surface, you can pull the axles without oil splilling any oil. The oil isn't supposed to sit on the axles or they would constantly leak.
I would figure the same for an auto tranny.
Old Mar 22, 2005 | 03:46 PM
fourthgenhatchB17's Avatar
Default Re: !!!!!!!!!Transmission Fluid!!!!!!!!!!!? (4drEF)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4drEF &raquo;</TD></TR><TR><TD CLASS="quote">Hmmm. On a manual tranny car that is on a flat surface, you can pull the axles without oil splilling any oil. The oil isn't supposed to sit on the axles or they would constantly leak.
I would figure the same for an auto tranny.</TD></TR></TABLE>
But most likely the guy had the front of the car jacked up. I have changed axles before without any spills. Just change one axle at a time while ONLY jacking up one side at a time.
Old Mar 22, 2005 | 03:50 PM
GreenBean's Avatar
Default Re: !!!!!!!!!Transmission Fluid!!!!!!!!!!!? (fourthgenhatchB17)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fourthgenhatchB17 &raquo;</TD></TR><TR><TD CLASS="quote"> Just change one axle at a time while ONLY jacking up one side at a time. </TD></TR></TABLE>
<FONT SIZE="2"><FONT COLOR="red">Thats the key right there...</FONT></FONT>
kpop
19
Nov 30, 2023 08:42 PM
Vagitarian
17
Aug 3, 2012 08:45 AM
blazinsii
Oct 30, 2005 05:05 PM
97Alex
Mar 20, 2005 02:36 PM
EVIL_AWD
May 24, 2003 06:28 PM
