would going to 10.3mm spark plug wire give me an improvement over my 7mm's
Old Mar 22, 2005 | 10:46 AM
srv3fender's Avatar
Default would going to 10.3mm spark plug wire give me an improvement over my 7mm's
Ive got a d16y8 minime setup with the 2gen/4gen si dizzy and ngk spark plugs
Ive got some lifetime warranty 7mm wires from autozone that a guy gave me.
And im wanting to go to better wires. I found some 10.3 Obx's on ebay
and im wondering if its a good idea.
If i would get any gains. what might i expect.
Old Mar 22, 2005 | 10:48 AM
POE's Avatar
POE
Default Re: would going to 10.3mm spark plug wire give me an improvement over my 7mm's (srv3fender)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by srv3fender &raquo;</TD></TR><TR><TD CLASS="quote">Ive got a d16y8 minime setup with the 2gen/4gen si dizzy and ngk spark plugs
why are you wanting better wires? for my hp? becuase thats bs. you wont gain any performance from them. just save your wires. and spend your money on a nice cam for your car
Old Mar 22, 2005 | 10:51 AM
IHateJDM's Avatar
Default Re: would going to 10.3mm spark plug wire give me an improvement over my 7mm's (POE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by POE &raquo;</TD></TR><TR><TD CLASS="quote">
why are you wanting better wires? for my hp? becuase thats bs. you wont gain any performance from them. just save your wires. and spend your money on a nice cam for your car</TD></TR></TABLE>
Bigger wires won't matter unless you are running a serious coil. I really doubt your car is that heavily modded.
Old Mar 22, 2005 | 11:06 AM
BOOST_92's Avatar
Actually we built an ef with an obd1 gsr and stock honda wires made the best power. dyno proven. But they gotta be honda wires.
Old Mar 23, 2005 | 05:11 AM
srv3fender's Avatar
Default Re: (BOOST_92)
i hear of alot of people saying to use 8mm ngks
would that be better over the 10.3mm or is it still best to use 7mm
I got these ngk spark plugs and i want them to have the best spark.
When i said gains i didnt mean straight horespower, i meant over things as well, like gas mileage, and acceleration or torque.
Now i swear, i use to go to this racing shop and they had this current machine to show the difference in spark power between stock and aftermarket spark plug wires and it supposedly wasnt a trick cause you could switch the wires and spark plugs and still get the same effect. But anyway i think they were 9.3mm wires and they had a big blue clean looking electric current/arch amd the stock wires had a nasty dark small arch.
So are you guys says that less current is going to be better for your car
Old Mar 23, 2005 | 05:35 AM
jasb16A2aSIR2's Avatar
Default Re: (srv3fender)
I wouldn't put any autozone stuff on my honda its all sh#!. I would use the ngk wires or go buy some honda wires, i don't think that see to much gain maybe in gas mileage and very lil in acceleration if any. I don't think any wire over 8mm is going to do you any good but wast your $$ unless your buy a MSD setup.
Old Mar 23, 2005 | 05:36 AM
srv3fender's Avatar
Default Re: (jasb16A2aSIR2)
whats an msd setup
Old Mar 23, 2005 | 05:38 AM
IHateJDM's Avatar
MSD is an aftermarket ignition. Get some NGK blues.
Old Mar 23, 2005 | 07:54 AM
Stfunkys's Avatar
Default Re: (93delslo)
MSD stands for Multiple Spark Discharge. It's a patented design that fires the spark plug multiple times every time the unit is triggered.
What will a MSD unit do for me? Easier starts, more horsepower, better throttle response are the expected results from a MSD capacitive discharge ignition - whether it's an analog or digital system.
With the multiple spark discharge of a MSD ignition, it is finally possible to completely ignite the air/fuel mixture in the cylinder - giving you more horsepower. In a 2-stroke engine this is important. When you suddenly give the engine "the gas" after idling, the engine will bog down. This is the result of a weak stock ignition trying to burn off the excess fuel that has built up in the cylinder. The stock ignition's weak spark can't do the job. A MSD ignition has a hotter spark to start with, and along with the multiple spark discharge, a MSD ignition will thoroughly ignite the air/fuel mixture.
msd- msd is an ignition settup which give you more spark.
spark= good!
it will essentially make you go faster.
thats also why people change their spark plugs
Modified by Stfunkys at 9:14 AM 3/23/2005
Old Mar 23, 2005 | 08:12 AM
srv3fender's Avatar
Default Re: (Stfunkys)
so msd ignition is that pretty box thats always bolted to peoples chassis right, its not a distributor.
Is there an msd ignition system for my crx with crx si dizzy and d16y8 engine?
Cause if what u say is true, then i might need one
Ive heard that msd's burn out coils and ignitors quickly is that true?
Old Mar 23, 2005 | 08:21 AM
Street Ghost's Avatar
I would buy either OEM or NGK spark plug wires. Some of the high horsepower guys are still using OEM or NGK spark plug wires.
Old Mar 23, 2005 | 08:36 AM
boostedcivicsir's Avatar
Mr. Badwrench
it is not a gain you will notice. a good set of NGK wires will out perform OBX wires IMHO, i personally have been using msd's with no issues. most people here swear by NGK's though.
Old Mar 23, 2005 | 08:49 AM
Default Re: would going to 10.3mm spark plug wire give me an improvement over my 7mm's (Street Ghost)
yes there are msd ignitions for your crx, I run the SCI-L sport compact ignition with ss blaster coil. That same setup will work on your crx.
Old Mar 23, 2005 | 09:42 AM
menkio's Avatar
Default Re: would going to 10.3mm spark plug wire give me an improvement over my 7mm's (jasb16A2aSIR2)
dood.. you have a 16 second honda civic.. spark plug wires are the last thing you need... lol.
Old Mar 23, 2005 | 10:50 AM
srv3fender's Avatar
Default Re: would going to 10.3mm spark plug wire give me an improvement over my 7mm's (menkio)
yeah thats 16 secs in you drive it
the original crx si's with 105 hp did 16's
MSD is kinda pricy, any good knock offs?
Old Mar 23, 2005 | 11:10 AM
civiccoupe94's Avatar
i bought some 8mm ACCEL wires from ebay for 30 shipped and they worked great. i can feel the imporvement like at 6,00 rpm.. lol.. i have a 94 DX.. its a tad bit better on power and my gas mileage got a tad bit better.
Old Mar 23, 2005 | 11:12 AM
Default Re: (civiccoupe94)
6,000 rpm... typo
Old Mar 23, 2005 | 11:21 AM
IHateJDM's Avatar
I bought NGK blues and didn't notice a damn bit of difference. With a stock motor, you will only see improvements if your current wires are messed up. Plug wires are maintence, not performance on a stock engine.
Old Mar 23, 2005 | 11:52 AM
EE_Chris's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by srv3fender &raquo;</TD></TR><TR><TD CLASS="quote">MSD is kinda pricy, any good knock offs?</TD></TR></TABLE>
The stock ignition system (coil, igniter, cap, rotor, plugs and WIRES) can easily handle 300whp without breaking a sweat - just stick with it.
Its been proven time and time again....
95gsr916
Apr 2, 2012 09:50 PM
OrangeTeggy
Apr 4, 2009 12:43 PM
srv3fender
15
Mar 23, 2005 09:09 AM
Jaydeep
14
Aug 17, 2004 10:24 PM
shivic
Jan 4, 2004 04:36 PM
