Suspension & Brakes Theory, alignment, spring rates....
do i drille to install a strut bar?
Old Mar 22, 2005 | 08:35 AM
97civic123's Avatar
Default do i drille to install a strut bar?
i wanted to install a stock strut bar but is drilling the best way to get the hole for it?
Old Mar 22, 2005 | 09:40 AM
Dave421's Avatar
Default Re: do i drille to install a strut bar? (97civic123)
if you look under the hood, you probably have two black grommets or plugs on each side already. The holes are usually already drilled and they just put the plug in them. You'll have to use a nut & bolt since you don't have studs there but that shouldn't be an issue.
Old Mar 22, 2005 | 04:12 PM
97civic123's Avatar
Default Re: do i drille to install a strut bar? (Dave421)
i looked, there are no black gromets except teh same place as the one shown in the picture.
Old Mar 23, 2005 | 08:05 AM
Dave421's Avatar
then drill, you may have indentions or something to help you figure out where. Otherwise, just line it up and go to town. Just make sure when you attach it, you put the bolt up through the fender from the bottom.
Old May 13, 2005 | 07:47 AM
b18blackek's Avatar
i have always been curious bout this, i see doodes with EK's with stock CTR strut bars and i donno how the bolt them in..
Old May 13, 2005 | 12:36 PM
igo4bmx's Avatar
hey havier
whats going on
i just drilled holes for my strut bar..
Old May 13, 2005 | 01:59 PM
donut.'s Avatar
Default Re: (igo4bmx)
i didn't have holes for my gsr strut bar, so i drilled holes
Old Jun 26, 2005 | 02:26 PM
CivicSlid3's Avatar
I just went to PasswordJDM this weekend and picked up an "EK CTR front strut tower bar." It was for my 97 hatchback. So today, I went to try and see the bolting areas and NO HOLES. I got scared because I didnt know what to do with it, good thing to know it is possible to drill the hole yourself. Whew!!!
Old Jun 26, 2005 | 07:32 PM
EK k kay's Avatar
Default Re: do i drille to install a strut bar? (CivicSlid3)
On non Si 96-00 Civics they don't have the holes predrilled and don't have the bolt welded on the mounting points. All you have to do is drill holes where the markings are on each shock tower and get some nuts and bolts from the hardware store.
apalmucci
22
Mar 23, 2011 01:36 AM
mrdeadman
Apr 20, 2006 04:24 PM
h22vt
Mar 21, 2006 03:49 AM
hprelude93
Nov 19, 2005 12:56 PM
Drews Bitch
Nov 19, 2002 01:00 PM
