Cluth Noise?!
Old Mar 22, 2005 | 07:34 AM
ShadyBAB's Avatar
Default Cluth Noise?!
When I Engage my clutch on my EG it squeaks really bad. Is there a way I can WD-40 it? I've Sprayed lube on the clutch from underneath the steering wheel, but it didnt really seem to do anything.
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: Cluth Noise?! (ShadyBAB)
Change your master cylinder before it goes completly.
Old Mar 22, 2005 | 09:21 AM
ShadyBAB's Avatar
Is their a temporary fix for now. At least to stop the squeaking? bump
Old Mar 22, 2005 | 10:30 AM
AutoXer's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ShadyBAB &raquo;</TD></TR><TR><TD CLASS="quote">Is their a temporary fix for now. At least to stop the squeaking? bump</TD></TR></TABLE>
No. And I don't think your MC will go either. Every honda I've ever been in squeaks with the clutch pedal. I've heard that lubing the crap out of the bearing and arm during clutch install will quiet it for a while, but the noise will come back.
Old Mar 22, 2005 | 11:29 AM
ShadyBAB's Avatar
Default Re: Cluth Noise?! (EX_AutoXer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EX_AutoXer &raquo;</TD></TR><TR><TD CLASS="quote">
Thank you very much for all your help guys!
Old Mar 22, 2005 | 12:57 PM
ironlung78's Avatar
you may want to start by lubing where the slave cylinder rod meets the clutch fork. Lots of times the end of the clutch fork starts to rust and you hear the metal to metal. If its not that then its probably your release bearing..
If you have an aftermarket clutch lots of times they come with a release bearing thats made of plastic and metal and squeaks. Thats why its better to spend the extra $$$ and get the all metal oem bearing..
YAH YAH
Jun 11, 2007 09:59 AM
PGHDC5
Sep 4, 2006 06:25 PM
M2B4
Apr 5, 2006 08:02 PM
viktoryv1
Feb 11, 2006 08:44 PM
civickidd99
Sep 26, 2003 03:03 PM
