brakes system.
Old Mar 22, 2005 | 04:05 AM
PaImportTuner's Avatar
Default brakes system.
so yesterday i'm driving 45 mph on businnes highway. light turn red, i brake slowly and the closer i get to the light i depress the pedal more lil by little but guess what.. brake let loose pedal goes to the floor and no resistance and i keep rolling what do i do?? downshift to 1st and rip thru the light hoping i dont get Tboned so for the next 15 minutes i drive home with no brakes using trans to brake which isnt hard for the jdm s1 to do.
scenario.
no fluid in reservoir, so i put brake fluid in.. pump pedal and front driver and rear passenger drum is spraying brake fluid on rim and ground.
anyone had this happen to them? being my 5th EF/ED i have owned i NEVER had this happen to me once.
*so i have new brembo blanks and brembo rear drums. that i've been procrastinating putting on the crx.
Old Mar 22, 2005 | 07:22 AM
BeavisB16's Avatar
Default Re: brakes system. (PaImportTuner)
why didn't you use the E-brake?
Old Mar 22, 2005 | 07:27 AM
Ass$nyper's Avatar
Pirate General...YARRRR
Default Re: brakes system. (BeavisB16)
wow thats scary good thing you are ok.
Never happened to me or even heard of it happening to a 4th gen
CRX_Control's Avatar
whoa thats scary , lucly you went home alright , it never happened to me yet but i know that i just did a rear break upgrade so , hopefully everything if snug . (bastard above me stile my lines )
Old Mar 22, 2005 | 07:28 AM
EP3_05's Avatar
Well the rear leak is probably the wheel cylinder. The front leak could be the caliper or maybe the brake line is damaged.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BeavisB16 &raquo;</TD></TR><TR><TD CLASS="quote">why didn't you use the E-brake?</TD></TR></TABLE>
i did and nothing happend i kept rolling. right now the car is in my driveway in gear so it doesnt roll away.with a 2x4 in the back of tire in rear.
i was in the process of replacing all the brakes soon with the brembo blanks and drums.
Old Mar 22, 2005 | 07:30 AM
Default Re: brakes system. (91civic)
update the rear passenger side(drum) is the only spot of leaks i double checked. the front is just alot of brake dust.
i'll just drive 1 of the other cars..
but for now i'll be trail riding for a couple of hours.
EP3_05's Avatar
Yup then it is the wheel cylinder. Replace it asap.
Old Mar 22, 2005 | 07:55 AM
i wonder if left and right wheel cylinders are interchangable? off same vehicle.
Old Mar 22, 2005 | 07:58 AM
EP3_05's Avatar
You can make them work but I would just get two, one for each side. The coupling for the brake line faces at an awkward angle if you use a left one on the right and vice versa.
Old Mar 23, 2005 | 07:21 AM
JohnnieChimpo's Avatar
SOunds like you lost the seal in your rear cylinder. They are easy to change. In fact I think I have a new NAPA right rear cylinder for an 89HF in my car now. I bought both rears for inspection and replaced the left one. A few weeks later the right one started to leak and I installed my Teg rear discs instead.
Old Mar 23, 2005 | 07:38 AM
bagpipe goatee's Avatar
while you're at it, inspect the metal brake line on the trailing arm and where it comes from out of the car, those tend to rust out bad and fail. my friend's civic met its end like that and mine almost did too.
Old Mar 24, 2005 | 09:32 AM
Default Re: (bagpipe goatee)
yeh i just order left and right rear wheel drum cylinders, hardware kit and stainless braided kit.
this will accompany my inventory of brembo blanks, axis hi-performance kevlar pads, brembo drums and shoes that i already have.
and the custom 3" straight back under gas tank and exit under license plate exhaust is being done. BIG WEEKEND for me. all of this is setting my turbo setup back damnit.
Chilly56
Honda Civic (2006 - 2015)
Nov 23, 2019 08:46 AM
Novacoma
Honda CR-V & Element
Jun 28, 2017 01:35 PM
adamcm16
Apr 10, 2014 05:07 PM
Kennyjai
Oct 17, 2011 11:55 AM
love_my_ekcoupe
Suspension & Brakes
May 28, 2010 03:32 AM
