Front Brake Conversion (90-93 integra)
Old Mar 21, 2005 | 11:55 PM
mbsi's Avatar
Default Front Brake Conversion (90-93 integra)
Hi all.
Has anyone on the site ever install 90-93 Integra front spindles/disk brake conversion for an ED hatch (91 DX)?
If so, have you run into any problems with it?
Im hearing rumors that the swap shouldn't be performed
Anyone out there who has experienced with this have a word on it?
thx
BTW
Done a search, only this came up
https://honda-tech.com/zerothread?id=1184078
which says that this dude did it np
Old Mar 22, 2005 | 11:05 AM
mbsi's Avatar
Default Re: Front Brake Conversion (mbsi)
ttt
Old Mar 22, 2005 | 12:01 PM
crxgator's Avatar
search for brake in the crx section in archived topics...there are 10000 topics on this...
Old Mar 22, 2005 | 12:33 PM
JUSTCRX's Avatar
The ideal brake swap for a 2G CRX is from a 90-91 Civic EX. The DA's knuckle isnt the same as EF cuz of the alignment issues. I've heard people that the tires rub on the fender with DA knuckles.
Some people say is doable and some say it isnt.
I got EX brakes myself on my old car and it feels awesome.
Old Mar 22, 2005 | 02:21 PM
crexer's Avatar
Default Re: Front Brake Conversion (JUSTCRX)
the teg knuckles work fine if you use the crx stock upper A-arm and you retain your stock crx lower arm. ONLY use the integra knuckle and your golden. The only people that have alignment issues are the ones who used all the integra arms then its totally out of whack and probably not able to align.
Old Mar 22, 2005 | 02:55 PM
Targa250R's Avatar
be professional
The G2 Integra knuckles are taller than G4 Civic knuckles, and you'll end up with a more aggressive camber curve. So depending on where your ride height is, you may end up with an undesireable alignment and/or clearance issues . . .
Ideally, you'd want '90-91 EX or JDM EF8/EF9 knuckles.
Old Mar 22, 2005 | 03:01 PM
DocSean's Avatar
Default Re: Front Brake Conversion (Targa250R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Targa250R &raquo;</TD></TR><TR><TD CLASS="quote">The G2 Integra knuckles are taller than G4 Civic knuckles, and you'll end up with a more aggressive camber curve. So depending on where your ride height is, you may end up with an undesireable alignment and/or clearance issues . . .
Ideally, you'd want '90-91 EX or JDM EF8/EF9 knuckles.</TD></TR></TABLE>
Why swap knuckles when you can upgrade to the 90-91 size front brakes without them, atleast according to this post https://honda-tech.com/zerothread?id=1171175
Old Mar 22, 2005 | 03:27 PM
LSvtec03's Avatar
Default Re: Front Brake Conversion (spankjelly)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spankjelly &raquo;</TD></TR><TR><TD CLASS="quote">Why swap knuckles when you can upgrade to the 90-91 size front brakes without them, atleast according to this post https://honda-tech.com/zerothread?id=1171175</TD></TR></TABLE>
i'm in the middle of this as we speak
Old Mar 22, 2005 | 08:13 PM
mbsi's Avatar
thanks for the replies guys
I actually got a hold of the 90-93 teg front spindles and installed everything with my stock upper and lower arms and the rest of the suspension.
The car drives perfect, the car is at stock height right now and the camber is perfect and the wheels are perfectly straight.
The car looks exactly how it was with the stock spindles on it.
So im happy with the swap, and these brakes are freakin awesome, best upgrade ever.
Im just in the process now..looking for a booster, master and proportion (sp?) valve.
Thanks guys for the help
Old Mar 22, 2005 | 08:22 PM
DocSean's Avatar
Default Re: (mbsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mbsi &raquo;</TD></TR><TR><TD CLASS="quote">thanks for the replies guys
Thanks guys for the help</TD></TR></TABLE>
What differences exactly did you notice? What is the differences in the brakes, just the larger rotor?
Old Mar 22, 2005 | 08:36 PM
EL Vap133's Avatar
Default Re: Front Brake Conversion (crxgator)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxgator &raquo;</TD></TR><TR><TD CLASS="quote">search for brake in the crx section in archived topics...there are 10000 topics on this...</TD></TR></TABLE>
sidewayz2013
Apr 16, 2014 11:15 AM
importfan7
Mar 24, 2006 09:55 AM
SpeedSin
Mar 14, 2005 11:01 AM
the-pepsi-man
Jan 8, 2005 01:07 AM
98AccordEX
Jun 29, 2003 02:22 PM
