D16Z6 parts compatible with CX engine?
Old Mar 21, 2005 | 11:01 PM
H22AEG2's Avatar
Default D16Z6 parts compatible with CX engine?
Just got a 95 CX HB. This thing is so freaking slow. Anyways, I have a D16Z6 with spun rod bearings, and a damaged head. It also has a header. My questions..
Is the header compatible with the CX engine?
Is the intake manifold and throttle body compatible with the CX engine?
If said parts are compatible, is any tuning going to be necessary to runs these parts on the motor safely?
I am just looking for a little more pep. This thing is going to be the daily driver, so I am not about to spend any money to "tune" an 8 valve.
TIA
Old Mar 21, 2005 | 11:12 PM
Kendall's Avatar
Gains with bolt-ons will still be minimal on the D15B8. Find a functional Z6 head, along with a Y8 manifold and just an ebay header and you'll notice a world of difference all for a couple of hundred bucks. It's also very much worth the time to swap in the Z6 tranny assuming yours has one.
Old Mar 21, 2005 | 11:14 PM
hatchling37's Avatar
Default Re: D16Z6 parts compatible with CX engine? (H22AEG2)
Yes, yes, and yes. You shouldn't have to take any precautions as these parts are bolt-ons and compatible with the ECU you have in there. I would suggest you get the tranny from that beotch. It'll do way more for you than any of the stock parts will, trust me, I know
Old Mar 21, 2005 | 11:23 PM
H22AEG2's Avatar
Default Re: D16Z6 parts compatible with CX engine? (hatchling37)
Yes, I have the trans too. I read some more threads, and that looks like a real big helper. I figured the gains were minimal, I just need a little more so that I can atleast merge into traffic. If I switch to vtec that will cut the fuel economy drastically. I know I can't have my cake and eat it too, but dammit, this car is too f'ing slow.
Sad thing is today, it was a little windy, I was on the interstate and had it floored in fifth for almost 4 miles, only got up to 84mph.
Old Mar 21, 2005 | 11:26 PM
Kendall's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H22AEG2 &raquo;</TD></TR><TR><TD CLASS="quote">Sad thing is today, it was a little windy, I was on the interstate and had it floored in fifth for almost 4 miles, only got up to 84mph.</TD></TR></TABLE>
If it makes you feel any better, I had a stock D15B8 with a messed up clutch in my ITR for a while. Talk about something that couldn't get out of it's own way.
Old Mar 22, 2005 | 12:14 AM
B16aDasher's Avatar
Default Re: D16Z6 parts compatible with CX engine? (Kendall)
yeah, before i swapped, the most i could get is eighty-something mph. It was a lttle fun flooring the gas all the time tho.
Old Mar 22, 2005 | 02:16 AM
isckeg's Avatar
Default Re: D16Z6 parts compatible with CX engine? (B16aDasher)
swap over z6 tranny, z6 IM complete, headers find z6 head use p28 there you have it minime bady i did the mini me swap on my b8 it was fun really high compression i liked it vtec kicked in surrprisingly hard nothing like my gsr swap none the less i had fun with it until i spun a bearing going about 120 mph
Old Mar 22, 2005 | 02:18 AM
isckeg's Avatar
Default Re: D16Z6 parts compatible with CX engine? (isckeg)
oh yeah get rid of cx exshaust my dicks fatter than those pipes get custom or after market
Old Mar 22, 2005 | 05:59 AM
H22AEG2's Avatar
I have been seeing some threads about the ITR exhaust. Does this system bolt right up?
92civichbor
Aug 22, 2008 08:16 PM
BrokeasHell
Nov 7, 2006 03:36 PM
Rev-Olution
Nov 1, 2003 04:54 PM
AVXHATCH
Oct 7, 2003 08:25 AM
