Suspension & Brakes Theory, alignment, spring rates....
camber settings?
Old Mar 21, 2005 | 10:53 PM
volkdlr's Avatar
Default camber settings?
What does everyone here run? I know it depends on the car set up/track and all but just curious.
If you can list your:
car
shocks
spring rates F/R
camber F/R
example
EK hatch
JIC FLTA2
7K/10K
-2.5 degrees
-.5 degrees
Old Mar 21, 2005 | 11:55 PM
Dirk-EG's Avatar
Default Re: camber settings? (volkdlr)
How can you run such a difference, front/back.. did you correct it at the back or are you running THAT much lower in the front?
Old Mar 22, 2005 | 05:33 PM
travis's Avatar
Default Re: camber settings? (Dirk-EG)
my 88 crx si has GC/Eibach/Konis at 500F/600R and a ST rear sway bar with no front bar. I currently run around -2.5*F/3.5*R.
Old Mar 22, 2005 | 05:41 PM
R.S.'s Avatar
Default Re: camber settings? (travis)
i've got about -2 in front and -1 in rear...neva really played w/ it cuz i don't have camber adjustment, but those are the numbers i got after my corner weighting and alignment.
95 dc4 integra
Koni Yellow
GC's 6kg/mm F, 7kg/mm R
-2 F, -1 R
LX4CYL
19
Nov 1, 2004 11:53 AM
B18C5-EH2
25
Mar 31, 2004 07:28 AM
THE GAME IS THICK
17
Nov 28, 2003 06:03 PM
hicamjunkie
11
Dec 31, 2002 07:13 AM
keithv
Aug 13, 2001 08:42 PM
