witch b 20 should i get
"should i get the b20b then? "
"B20z is newer, has Higher compression and a little bit more HP....
also, the intake manifold is comletely different between the two....."
Didnt you see what phatwhippin posted?
B20 specs:
97-98
HP 126 @ 5400
Torque (ft-lbs) 133 @ 4300
Ecu redline 6200
compression ratio 8.8
Cyl Bore 84mm
Stroke 89.0mm
B20Z specs:
99-00
HP 146 @ 6200
Torque (ft-lbs) 133 @ 4500
Ecu redline 6700
compression ratio 9.6
Cyl Bore 84mm
Stroke 89.0mm
some differences:
b20b, tall intake manifold.
b20z, manifold is more like an ls man.
b20z comes with a knock sensor
b20b does not
good luck trying to find a b20z
B20 specs:
97-98
HP 126 @ 5400
Ecu redline 6200
Cyl Bore 84mm
Stroke 89.0mm
B20Z specs:
99-00
HP 146 @ 6200
Ecu redline 6700
Cyl Bore 84mm
Stroke 89.0mm
some differences:
b20b does not
felipe69
10
Apr 12, 2009 02:33 PM
