What can i weld to aluminized steel? aluminum or steel?
so i bought some U bends from jcwhitney to make my charge pipes, but they're made of aluminized steel. i need to order a greddy type s bov flange, and i can't figure out if i need to order the flange in aluminum or steel.
http://www.jcwhitney.com/autop...202.5
my basic understanding is that you can't weld aluminum to steel or vice versa, but i don't know what the rule of thumb is for "aluminized steel"
this will be welded together using an ARC welder if that helps any.
you can weld aluminized steel using a mild steel wire
get the steel flange
essentially aluminized steel is just a coating . dont breath that **** though. it gives off cyanide when welded.
BeArDy
Welding / Fabrication
12
May 18, 2011 01:50 AM
slowdx
Sep 26, 2004 06:32 PM
