Fuel pump upgrade
Old Mar 21, 2005 | 04:40 PM
HondaIntegraR's Avatar
Default Fuel pump upgrade
Hi, guys i was just wondering after what hp do you need to upgrade your stock GSR fuel pump?Thanks in advance.
Old Mar 21, 2005 | 08:09 PM
00Red_SiR's Avatar
All Motor Mentor
Default Re: Fuel pump upgrade (HondaIntegraR)
Anything over 300 crank hp and the pump becomes marginal. That can vary depending on a pumps age and condition though.
Old Mar 21, 2005 | 08:13 PM
Kendall's Avatar
If you have plans for anything over 250, it's a good idea to upgrade based simply upon the fact that it's too cheap and too easy to simply "leave out."
Old Mar 21, 2005 | 08:25 PM
hotdoggies's Avatar
Default Re: (Kendall)
What mileage would you think a fuel pump change would need to be done.
Old Mar 22, 2005 | 12:18 AM
Default Re: (hotdoggies)
since i own a 95 integra, my fuel pump is going to be about 10 years old, just gonna change it for a new one: should i choose oem or aftermarket?
setup:
85.5 gsr block at 11.5 cr
stock stroke
portflow gsr head
ericks racing header
skunk2 manifold
bc 4
high flow rail + fuel pressure regulator
rc 370
70 mm throttle body
Old Mar 22, 2005 | 08:58 AM
Default Re: (HondaIntegraR)
bump
Old Mar 22, 2005 | 09:28 AM
LSVTEC 91 Civic's Avatar
Banned
I'm putting down 190whp with a stock 91 HB fuel pump and prelude injectors... I'm already getting more than enough fuel as-is.
Old Mar 22, 2005 | 10:27 AM
Default Re: (LSVTEC 91 Civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSVTEC 91 Civic &raquo;</TD></TR><TR><TD CLASS="quote">I'm putting down 190whp with a stock 91 HB fuel pump and prelude injectors... I'm already getting more than enough fuel as-is.</TD></TR></TABLE>
I plan on putting down at least 220, will the stock gsr pump workout?
Old Mar 22, 2005 | 04:28 PM
00Red_SiR's Avatar
All Motor Mentor
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondaIntegraR &raquo;</TD></TR><TR><TD CLASS="quote">since i own a 95 integra, my fuel pump is going to be about 10 years old, just gonna change it for a new one: should i choose oem or aftermarket?
setup:
stock stroke
portflow gsr head
skunk2 manifold
bc 4
rc 370
70 mm throttle body</TD></TR></TABLE>
Stock pump is certainly adequate but a 190lph Walbro pump is cheap in the classified section here ($78 or so) so you can't go wrong with that either.
Old Mar 23, 2005 | 12:22 AM
Default Re: (00Red_SiR)
is the 190 lph walbro loud?
Old Mar 23, 2005 | 04:55 PM
00Red_SiR's Avatar
All Motor Mentor
Some say it is, others say it isn't. Make sure it's installed correctly with a new sock filter properly placed and it "shouldn't" be much louder than stock.
jdmfoglights
Feb 6, 2014 06:56 AM
motrayEG6
Jul 7, 2008 12:01 PM
lv6l
Jun 5, 2006 09:33 PM
Spins
Apr 13, 2005 04:12 AM
