Where to buy an O2 sim
Old Mar 21, 2005 | 04:35 PM
KevinWVU's Avatar
Default Where to buy an O2 sim
I have tried to search but could not find an answer. Does anyone know where to get a secondary O2 sim for my Cat Convertor? Has anyone had any problems with not having the actual O2 sensor in place, will it effect the way the engine functions?
Old Mar 21, 2005 | 04:46 PM
The Phil's Avatar
Default Re: Where to buy an O2 sim (KevinWVU)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KevinWVU &raquo;</TD></TR><TR><TD CLASS="quote">I have tried to search but could not find an answer. Does anyone know where to get a secondary O2 sim for my Cat Convertor? Has anyone had any problems with not having the actual O2 sensor in place, will it effect the way the engine functions?</TD></TR></TABLE>
You'll get a CEL. Engine will run like a Geo. I've seen like a billion of them.
First thing that showed up when I searched: o2 sim
EDIT: Even better. DIY o2 sim
Old Mar 21, 2005 | 09:23 PM
PrettyLude's Avatar
try and get a casper's electronics one, plug and play, no splicing at all
http://www.casperselectronics.com
Old Mar 21, 2005 | 11:22 PM
cyco's Avatar
Default Re: (PrettyLude)
those sims are put inline between the sensor and the harness? is there any benifit to using a sim opposed to getting a new o2 sensor?
Old Mar 22, 2005 | 09:33 AM
KevinWVU's Avatar
I looked at the Casper Eletronics one, I like the plug and play feature. If am going to try to run the actual sensor first. If I trip a CEL then I will have to get the O2 sim.
Old Mar 22, 2005 | 10:25 AM
foshizllmynizl's Avatar
Default Re: (KevinWVU)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KevinWVU &raquo;</TD></TR><TR><TD CLASS="quote">I looked at the Casper Eletronics one, I like the plug and play feature. If am going to try to run the actual sensor first. If I trip a CEL then I will have to get the O2 sim. </TD></TR></TABLE>
It better not be your DD, if it is good luck with thoose 5 days between order and shipment.
Old Mar 22, 2005 | 11:34 AM
PrettyLude's Avatar
you will still get that light for catalyst inefficiency or below threshold
Old Mar 23, 2005 | 09:45 AM
KevinWVU's Avatar
I installed an ebay High Flow Cat last night, it is not really a Cat, it is a resonator with a bung for the O2 sensor. OBX racing. So far it has not tripped the CEL, I have only driven it once, on a short trip. I hear an exhaust leak though, so I am going to recheck the torque settings, and take it for another test spin. Thanks for the responses.
guamie
May 5, 2008 10:50 PM
AGENT 99
Mar 5, 2006 09:46 AM
zerovandez
Feb 5, 2006 01:56 PM
1998teg
May 20, 2005 05:25 AM
pr_tony_montana
16
May 13, 2005 10:14 AM
