1993-1995 Civic Ex coupe. ABS a problem?
I am looking for a near mint 5 speed Civic Ex coupe with ABS. I was just wondering if it really makes a difference if the car has ABS or not. Would this cause more problems? I'm new to this chassis and am just curious about this feature since this appears to be the only model that allowed Antilock Brakes as an option.
The only problems I have seen with ABS is that old, dirty brake fluid corries the passages. This will make the ABS less efficient.
Yes, it was a option on coupes.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ProjectCRXtacy »</TD></TR><TR><TD CLASS="quote">I am looking for a near mint 5 speed Civic Ex coupe with ABS. I was just wondering if it really makes a difference if the car has ABS or not. Would this cause more problems?</TD></TR></TABLE>
No. It's the same ABS system used in '94-01 Integras (except RS and Type-R). Calipers, rotors, and pads are all identical to '94-01 Integra non-RS/R as well.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">I'm new to this chassis and am just curious about this feature since this appears to be the only model that allowed Antilock Brakes as an option.</TD></TR></TABLE>
All '92-95 EX sedans had ABS as standard equipment. The EX coupes with optional ABS are much less common.
What the hell do you think you are doing? Get off honda-tech and get back to work.
Your IT Administration is always watching.
oh shut up. What if my "IT Admin" saw my post from my Tmobile Sidekick? Can't run that network. Go away, and get back to work. Quit watching the Honda-Tech forums while you're supposed to be stabilizing our network.
vfr700f2
Suspension & Brakes
Aug 6, 2011 06:49 PM
94eg!
16
May 12, 2005 08:43 AM
