Removing Axle
Old Mar 21, 2005 | 01:40 PM
homesauce's Avatar
Default Removing Axle
I'm dropping my tranny, and have a few questions for the guys that have done it before to replace the clutch/flywheel.
1) Is removing the axle from the brake rotor the only way to get enough slack to get the axle out of the tranny? If so-any tips on how to get that little divit up to unlock the bolt? That thing is pretty stiff.
2)Even though the Helm's says to remove the axle and intermediate shaft on the other side, Flyrod mentioned in a previous post that just unbolting the 3 bolts on the intermediate shaft is good enough. Any one can confirm this? I really hope so, because I do NOT want to take out another axle if I don't have to.
Old Mar 21, 2005 | 01:52 PM
AndyD's Avatar
Default Re: Removing Axle (homesauce)
Take the shock off control arm and undo the ball joint. That's the only way.
Old Mar 21, 2005 | 01:53 PM
Hawkze_2.3's Avatar
I never pulled the axle from the hub or anything, but if I remember right I popped the lower ball joint and disconnected the radius rod so then the hub/axle was able to move outward away from the tranny.
Old Mar 21, 2005 | 02:00 PM
homesauce's Avatar
Default Re: Removing Axle (Hawkze_2.3)
Nice, so basically I don't need to remove it from the actual brake rotor, and can just undo the ball joint, and that will give me enough slack to pry the axle out of the tranny?
Old Mar 21, 2005 | 02:08 PM
chitownrida's Avatar
Default Re: Removing Axle (AndyD)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AndyD &raquo;</TD></TR><TR><TD CLASS="quote">Take the shock off control arm and undo the ball joint. That's the only way.</TD></TR></TABLE>
sauce just like andyd says.. dont have to pop the axle from the hub... if you need help get at me
Old Mar 21, 2005 | 02:19 PM
homesauce's Avatar
Default Re: Removing Axle (chitownrida)
alright, i got it, thanks.
How about the intermediate shaft?
Where are you located at Chitownrida
Old Mar 21, 2005 | 09:30 PM
PrettyLude's Avatar
the intermediate shaft is held onto the block by 3 12 mm or 14mm bolts
Old Mar 22, 2005 | 12:56 AM
SKDRCR's Avatar
Default Re: (PrettyLude)
Actually, you don't even have to undo the balljoint.
take a look at this picture.
Just remove the stabelizer link nut #27
And remove #22 (shock absorber fork bolt) and #23 (radius rod bolt).
Turn the wheel and you should be able to push out on the suspension enough
for the axle to disconnect from the tranny.
I learned this from Tom (Prelittlelude) and it helped a ton.
Old Mar 22, 2005 | 12:58 AM
SKDRCR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrettyLude &raquo;</TD></TR><TR><TD CLASS="quote">the intermediate shaft is held onto the block by 3 12 mm or 14mm bolts</TD></TR></TABLE>
yeah just undo the 3 bolts to the block and follow the same procedure
that I stated earlier.
Old Mar 22, 2005 | 02:21 AM
homesauce's Avatar
Default Re: (SKDRCR)
Yea, so I just got done with removing everything, and now the tranny is loose, but removing it is going to be a pain.
I ended up removing the ball joint because it made it a lot easier to get the axle out of the tranny. I was searching and came across this really useful method where you stick a socket wrench between the lca and the knuckle by jacking it up, and then undoing the jack, then kicking down on the assembly. Popped out like a charm.
God, getting this tranny out is gonna be a bitch, this thing is so heavy, i can barely budge it and the intermediate shaft is still in there, and I think that's what's holding it up. The idea is to move the tranny towards the passenger side, so that the intermediate shaft has enough room to come out right? but the tranny doesnt really want to move that way.
Old Mar 22, 2005 | 03:50 AM
clemsoncb7's Avatar
Default Re: (homesauce)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by homesauce &raquo;</TD></TR><TR><TD CLASS="quote">Yea, so I just got done with removing everything, and now the tranny is loose, but removing it is going to be a pain.
God, getting this tranny out is gonna be a bitch, this thing is so heavy, i can barely budge it and the intermediate shaft is still in there, and I think that's what's holding it up. The idea is to move the tranny towards the passenger side, so that the intermediate shaft has enough room to come out right? but the tranny doesnt really want to move that way.</TD></TR></TABLE>
No, you should be able to(with a little finessing(sp?)) take the intermediate shaft out without the tranny out. I got it out fine, you just need to pull with enough force Good luck man, I'll hit you up later on AIM.
Old Mar 22, 2005 | 04:34 AM
flyrod's Avatar
Default Re: (maxvtec7500)
There is a writeup in the FAQ on this.
Old Mar 22, 2005 | 04:43 AM
Greyout's Avatar
Default Re: (flyrod)
even though it adds a few minutes to the job, removing the front subframe makes dropping the tranny ELEVENTY BILLION times easier. &lt;-- EDIT: I mean the one under the radiator....
I won't even mention putting that hunk of poo back up into the engine bay.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">And remove #22 (shock absorber fork bolt) and #23 (radius rod bolt).</TD></TR></TABLE>
check your numbers again
Old Mar 22, 2005 | 08:24 AM
homesauce's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by flyrod &raquo;</TD></TR><TR><TD CLASS="quote">There is a writeup in the FAQ on this.</TD></TR></TABLE>
Yea, are you talking about Behan's write up? If so, I've been using it, but it skips some of the harder parts, and I've been using the pictures as reference.
Old Mar 25, 2005 | 02:03 PM
BokChoy's Avatar
Splitting the ball joint is certainly not my first option, follow the diagrams provided and those axles will come like nothing. You'll likely have to remove the bearing block on the intermediate though. Good luck!
Old Mar 25, 2005 | 05:56 PM
Wiseguy619's Avatar
Default Re: (Greyout)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Greyout &raquo;</TD></TR><TR><TD CLASS="quote">even though it adds a few minutes to the job, removing the front subframe makes dropping the tranny ELEVENTY BILLION times easier. &lt;-- EDIT: I mean the one under the radiator....</TD></TR></TABLE>
I did this also when i recently swapped my SH tranny. Definetely a biatch to finaggle the tranny in and out. Definetely easier with someone helping you lift the tranny in and out. I also removed the axle from the hub. I thought the whole job sucked actually .
Old Mar 25, 2005 | 09:18 PM
prelittlelude's Avatar
check your numbers again </TD></TR></TABLE>
No hes got the right numbers. the way he wrote it is exactly how i do it every time. you get plenty of swing out so you can pull the axle out. on both sides. doing it this way you don't even need to take the wheel off.
neway that for the credit chris
Old Mar 25, 2005 | 11:15 PM
Sam1am26's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Greyout &raquo;</TD></TR><TR><TD CLASS="quote">removing the front subframe makes dropping the tranny ELEVENTY BILLION times easier. &lt;-- EDIT: I mean the one under the radiator....</TD></TR></TABLE>
Omg yes it does....
lowtegsr
Feb 1, 2008 07:18 AM
crx18c1
10
Apr 17, 2007 10:17 PM
B18CYAAA
Nov 30, 2006 10:59 PM
B2FiNiTY
Nov 14, 2004 11:08 AM
S.Celia
Jan 26, 2004 07:24 AM
