Intake and Exhaust Cams
I need to know if i can use jdm ctr intake cams and jdm itr exhaust cams or is it preferred to use ctr or itr intake and exhaust cams only? usdm or jdm or combination? make little or no difference? on a 95' Gsr
The CTR/ITR cam combo used to be the way to go but I would try and get you hands on some 98+ Type R cams because from then on they were the same specs. Hope this helps. Good luck.
vtecdc2
Sep 2, 2002 07:52 PM
