Throw Out Bearing Question
Old Mar 21, 2005 | 12:35 PM
91Notch5.0's Avatar
Default Throw Out Bearing Question
When ordering a new throwout bearing they asked if the clutch was 220mm or not?...Honestly I have no clue what they are talking about?...anyone know?..Thanks
Old Mar 21, 2005 | 12:38 PM
EP3_05's Avatar
Default Re: Throw Out Bearing Question (DSM2GNT95)
The clutches for the 88-91 ed chassis civic/crx are different. The 88 is different from the 89 and the 89 is different from the 90-91.
Old Mar 21, 2005 | 12:40 PM
91Notch5.0's Avatar
Default Re: Throw Out Bearing Question (91civic)
well this is for a jdm B16 so I was ordering for an Integra LS...dont know if it is 220mm or not..dont know the difference
Old Mar 21, 2005 | 12:42 PM
EP3_05's Avatar
Just get a bearing for the 90-91 integra LS and I am pretty sure that the 90-91 integra clutch is 220mm.
Old Mar 21, 2005 | 12:44 PM
91Notch5.0's Avatar
Ok thanks man
Old Mar 21, 2005 | 12:47 PM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
these are the part numbers for Acura;
91006-634-008 >pilot
22810-PS1-015 >throwout
Also see this thread for more numbers:
https://honda-tech.com/zerothread?id=1024595
FYI:220mm is the diameter of the clutch disc
Old Mar 21, 2005 | 01:21 PM
user 98292739's Avatar
wait i thought that the 88 was the only different spine count....88 was different then the 89-91 ef si tranny.
Old Mar 21, 2005 | 01:22 PM
EP3_05's Avatar
Default Re: (LoCoReX)
As far as spline count yes. The 89 has the same spline count as the 90-91 but a different clutch surface area.
Old Mar 21, 2005 | 03:47 PM
ummm but it bolts right up to my 91 clutch/flywheel? i have a 89 si tranny. i thought the only difference is the groves on the spindle which only tells what year it is?
Old Mar 23, 2005 | 11:45 AM
crx_of_fury's Avatar
88 and 89 have a smaller pressure plate than the 90 and 91's
Old Mar 24, 2005 | 10:23 AM
but..an 89 si tranny will still bolt up to the 91 motor...as long as you use the 91 clutch/flywheel and all that other neat stuff
Old Mar 24, 2005 | 10:32 AM
Mach69's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LoCoReX &raquo;</TD></TR><TR><TD CLASS="quote">but..an 89 si tranny will still bolt up to the 91 motor...as long as you use the 91 clutch/flywheel and all that other neat stuff</TD></TR></TABLE>
That is the exact setup I am using and I can verify that. I am using an '89 si tranny and 90 flywheel and clutch. Works well.
ilikejesus
May 8, 2009 05:16 AM
skiracer8148
Mar 27, 2007 10:52 AM
91civ
Jul 5, 2002 03:35 AM
dustin
Apr 19, 2002 03:08 PM
