will a sohc ECU work with dohc?
search is down at the moment and i need to know asap.
will the sohc ecu work with dohc? both manual. will it throw any codes?
i really just need to know if it'll run right.
Modified by BI8B at 12:58 PM 3/21/2005
it will run, but obviously not optimally. it may or may not throw CELs. if you use a non-vtec sohc ecu on a dohc non-vtec, you shouldnt get any CELs on startup. however, you may get 02 sensor or fuel system cel's down the road. same witha sohc vtec ecu on a dohc vtec motor. obviously if you run a vtec ecu on a non-vtec motor, you'll get CELs for the vtec stuff not being hooked up
yeah, it'll be non-vtec on both. would it run normally though? i just need it for a day.
i understand it'll throw fuel system but why 02 sensor?
E M Wynne
Engine Management and Tuning
Jul 17, 2017 04:04 AM
crxxxxxx
Sep 23, 2004 05:12 PM
JDMvtecDRAGSTA
Feb 25, 2002 05:28 PM
