Quick Question on Alternator
I have a 90 Hf crx, alternator died out and i am replacing today, but i was wondering if a alternator from a B16 will fit on it, i think its obd0. Dont know if mine is obd0 or obd1, anyone know if it will work?
From: I told you to wait in the truck in Texas, United States
A simple answer would be no,
but:
The wiring is the same,
but the pullies and the way it mounts are slightly different.
You could swap the two pullies,
then put a bolt through the lower mount
but you will have to rig up the top mount somehow...
so it might be easier just to find the correct one.
This was a "feasibility study" of using a stock alternator on a B16
[which would be the exact opposite of what you are trying to do..]
I swapped the pulley,and the lower mount was the same,but the top mount would have to be rigged up to work...
but:
Chief Wenceslaw
Nov 3, 2006 11:01 PM
JokerTypeR
Oct 28, 2006 07:36 AM
