Pic of S2K antenna on ITR?
Old Jan 24, 2002 | 06:33 PM
Nuts's Avatar
Default Pic of S2K antenna on ITR?
Or did anyone replace the stock one with something else? Is there anyway to disable the stock antenna and is that going to make a big different in radio reception?
thanks,
CS
[Modified by CS, 3:34 AM 1/25/2002]
Old Jan 24, 2002 | 06:35 PM
jetydosa's Avatar
25 Year Member
Default Re: Pic of S2K antenna on ITR? (CS)
http://www.bseries.net/html/garage/s2kantenna.php
Old Jan 24, 2002 | 06:37 PM
StinkyTofu's Avatar
well i don't have an ITR, but here is a pic of it on my car
Old Jan 24, 2002 | 06:43 PM
Nuts's Avatar
Default Re: Pic of S2K antenna on ITR? (B-18C1)
look nice! do u find the reception better/worse than the stock one?
Old Jan 24, 2002 | 06:46 PM
StinkyTofu's Avatar
to be honest, its a little worse. I recommend that when you install it, play with the wiring before your mount it! I'll redo it when i have time, but i never listen to my radio. my car is too loud anyways.
Old Jan 24, 2002 | 11:36 PM
o_Rage_o's Avatar
nice car! how much is it dropped, and with what parts?
Old Jan 25, 2002 | 12:16 AM
ITR 2K's Avatar
I want that OEM kit. Nice clean cut car.
Old Jan 25, 2002 | 12:28 AM
B2FiNiTY's Avatar
Default Re: Pic of S2K antenna on ITR? (ITR 2K)
OEM kit =
Old Jan 25, 2002 | 03:06 AM
ITR764's Avatar
Default Re: Pic of S2K antenna on ITR? (B2FiNiTY)
sweet GSR i the OEM look!!
if honda will ever get my antenna in i'll have one.
[Modified by ITR764, 7:07 AM 1/25/2002]
Old Jan 25, 2002 | 03:12 AM
Cosworth's Avatar
B-18C1 - really clean car!
Old Jan 25, 2002 | 08:46 AM
junglistgsr's Avatar
Default Re: Pic of S2K antenna on ITR? (Cosworth)
i angled mine back a bit, looks better than sticking straight up...
Old Jan 25, 2002 | 08:49 AM
CPR's Avatar
CPR
Default Re: Pic of S2K antenna on ITR? (junglistgsr)
Does anybody know if we can use the antenna mast straight off the s2k instead of the homemade one?
Old Jan 26, 2002 | 01:20 AM
StinkyTofu's Avatar
junglistgsr-hey i was wondering how you angled yours back without it sticking out to the side? I angled mine to the back and it looks great from the side, but when i look from the back of the car, it sticks out to the left! its like "what the heezy"...oh well, when i feel like cutting my hands up again then i'll fix it. nice pic btw
Old Jan 26, 2002 | 01:21 AM
StinkyTofu's Avatar
Default Re: Pic of S2K antenna on ITR? (o_Rage_o)
thanks! car is dropped with H&R sport springs (1.75 in the front and 1.5 in the rear), paired with some tokico illuminas. I think i need a camber kit and i really want to get an ITR sway bar.
Old Jan 28, 2002 | 09:13 AM
o_Rage_o's Avatar
thanks for the info, and is there also a body kit (skirts?) if so..again, was wondering which
Thanks!
Old Jan 28, 2002 | 10:21 AM
B2FiNiTY's Avatar
Thats the OEM bodykit. Runs about $350 unpainted. It includes the side skirts and rear unpainted.
Old Jan 28, 2002 | 10:45 AM
Solo2Vtec's Avatar
Is that the H&R race springs ? or just the sport
Old Jan 28, 2002 | 11:20 AM
BudMan's Avatar
Default Re: Pic of S2K antenna on ITR? (Jetydosa)
Thanks for pimping Bseries
Old Jan 28, 2002 | 11:56 AM
StinkyTofu's Avatar
Default Re: Pic of S2K antenna on ITR? (LSVtec2000)
Sports. I believe if i had the race springs my tires would be tucked inside my fenderwell.
Old Jan 28, 2002 | 01:01 PM
i angled everything, including the piece that you re-use from the stock antenna, i twisted that torwards the hatch side so that the antenna would face a bit torwards the hatch side (to the right) and also back so that it would like the the antenna on the S2000 which does the same...it angles back and in a bit....if you got the kit from chris blake, you can loosen it and angle it how you like and then tighten it all back up, thats what i did until i liked it
Old Jan 28, 2002 | 01:38 PM
JDM_Type-R's Avatar
Excluding tools, is the actual S2000 antenna all you need for this conversion? thanks.
Old Jan 28, 2002 | 01:44 PM
ITR764's Avatar
Default Re: Pic of S2K antenna on ITR? (JDM_Type-R)
i finaly got off my lazy azz and put mine on and i can tell you the rear end very stable under hard breaking because of the antanna plus i hated how tall the power one was
Old Jan 28, 2002 | 03:33 PM
Calavera's Avatar
Besides the s2k antenna, you'll need a mounting kit. You can either purchase a mounting kit, or build one yourself. I didn't want to go through all the trouble and make a kit by myself, so I just went and bought one from a guy for about 10~15 bucks.
The mounting kit comes with detailed instructions as well as some links to pics.
Took me about 1 hour because I had to drive and buy the neccessary tools.
Old Jan 28, 2002 | 03:46 PM
ITR764's Avatar
[QUOTE]Excluding tools, is the actual S2000 antenna all you need for this conversion? [QUOTE]
hit RStoR (chris) up. he has the kits all you need is the mast. longest part is taking all your interior chit out.
[Modified by ITR764, 7:48 PM 1/28/2002]
Old Jan 28, 2002 | 03:51 PM
InTegRa's Avatar
New User
Default Re: Pic of S2K antenna on ITR? (ITR764)
Yeah, Chris sent my kit out today Honda charged me 26.01 plus tax for the actual mast though
