problem with breaking axles in CRX with ZC swap
Old Mar 21, 2005 | 07:01 AM
onefiine69's Avatar
Default problem with breaking axles in CRX with ZC swap
I have a 91 CRX SI with a ZC motor and tranny in it. I just put new axles in it (axles for a 90 integra). However i have now broken 2 left axles. It happenes when i turn the wheel hard left and then bang they break. Seems like they might be too short? They are stock replacement axles for a 90 integra. Does anyone have any idea as to why the left axle keeps breaking on me? The car is lowered almost to the ground. Could this be the problem?
Old Mar 21, 2005 | 07:06 AM
CRXSiSage's Avatar
Default Re: problem with breaking axles in CRX with ZC swap (onefiine69)
what kind of whp are we talking here?
Old Mar 21, 2005 | 07:30 AM
brusk13's Avatar
what intermediate/jack shaft are you running.
Old Mar 21, 2005 | 07:35 AM
onefiine69's Avatar
between 100-120. Its all stock ZC motor with full exhaust.
Old Mar 21, 2005 | 07:37 AM
onefiine69's Avatar
the half shaft is supposed to be the right one for the ZC. The bolt holes lined up with the block.
Old Mar 21, 2005 | 08:13 AM
onefiine69's Avatar
I just called the place i got the motor/tranny from and they said that its doing that because my car is too low. Does that sound right?
Old Mar 22, 2005 | 06:09 AM
CRXSiSage's Avatar
Default Re: (onefiine69)
how low is your car dropped?
Old Mar 22, 2005 | 06:55 AM
EP3_05's Avatar
Well you say your car is to the ground which will accentuate any problems with the axles due to the extreme angle created by being that low. Raise the car up a bit and see if it helps.
Old Mar 22, 2005 | 07:01 AM
CRXSiSage's Avatar
Default Re: (91civic)
or if you want to keep the stance as it is, i believe there is a kit for mounting your engine/tranny higher to even out the angle a little, but i would just raise it a little bit.Damn, how do you get in the bastard???
Old Mar 22, 2005 | 07:32 AM
CRX_Control's Avatar
Default Re: (CRXSiSage)
your car is too low , the axles will sit at a angle , just look at your drivers side and you can see how angled it is , and do you experience wobbling? thats another sign that your car is too low .
Old Mar 22, 2005 | 08:10 AM
Rickdogg's Avatar
Default Re: (CRX_Control)
so if i have a 3inch drop on my stock dx my axles might break
Old Mar 23, 2005 | 11:59 AM
CRXSiSage's Avatar
Default Re: (Rickdogg)
i think thats mostly a horsepower deal.If you have more hp than is specified for those axles, maybe. but if you run the stock setup, there should be no problem. The problem kicks in when you are trying to turn the axles real fast and at an extreme angle to the tranny. Try this.Shut your arm in your car door and slam it. then try to play violin with that hand. get the idea?
Old Mar 23, 2005 | 05:20 PM
onefiine69's Avatar
My car has been lowered like 3 inches. The wheel wells had be to pulled out so the wheel could turn. Ill raise it up and see if that takes care of it thanks for all the help.
Old Mar 23, 2005 | 05:55 PM
mr_valentino20032000's Avatar
great jumping fish!!!
that sounds low
Old Mar 23, 2005 | 06:59 PM
the niz jiz's Avatar
Default Re: (mr_valentino20032000)
so whats a good length to be dropped, mine is lowered to 4....i havent had any problems but then again i only drove it 2 times
Old Mar 25, 2005 | 10:29 PM
90sihbw89crxfrnface's Avatar
i think u got sumtin that bent and making it even worse the ball joints are under tons more stress than the axels and they do have quite a bit of play in them i guess ur getting some cheap axels i had 3 in a row that all bound up from the store the axels have almost 90 degrees of usable movement my hatch is 2.5" down and the axles arent even parallel with the ground yet i got like inch and a half more before there even prallel
Old Mar 26, 2005 | 04:31 AM
SwissChEz82's Avatar
Default Re: problem with breaking axles in CRX with ZC swap (90sihbw89crxfrnface)
I've got my CRX with DOHC ZC and ZC tranny lowered to 2 inches. the axles are slightly angled up but not by much I think thats a good height. Now if I can just get some 15s instead of those damn 17s.
Old Mar 26, 2005 | 05:03 AM
91dxhatchswaped's Avatar
Default Re: problem with breaking axles in CRX with ZC swap (SwissChEz82)
if this dosnt help then your too low
http://www.ff-squad.com/tech/t...p.jpg
Old Mar 28, 2005 | 05:12 AM
onefiine69's Avatar
raised the car up and haven't broke an axle yet
Old Mar 28, 2005 | 06:24 AM
CRXSiSage's Avatar
did you try the violin thing?
Old Mar 28, 2005 | 06:28 AM
Keebler's Avatar
Bad motor mounts can also cause axles to break.
Old Mar 28, 2005 | 10:40 AM
4gCRX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRXSiSage &raquo;</TD></TR><TR><TD CLASS="quote">did you try the violin thing?</TD></TR></TABLE>
LMAO
Old Mar 29, 2005 | 06:34 PM
CRXSiSage's Avatar
Default Re: (4gCRX)
well i figured it would shed some light on what the car was trying to do.
crxguy406
Jun 29, 2013 09:50 PM
onefiine69
Mar 14, 2005 06:03 AM
onefiine69
Mar 12, 2005 05:08 PM
JDMVTEC
Nov 2, 2003 05:57 PM
kokujin
Apr 11, 2002 06:50 AM
