removing charcoal canister......
Old Mar 21, 2005 | 06:49 AM
Chase's Avatar
Default removing charcoal canister......
Im takin that **** out and was wondering what to do with the left-over hoses.....i pointed them out in this pic...Thanks everyone
Old Mar 21, 2005 | 06:51 AM
Twilight's Avatar
Default Re: removing charcoal canister...... (b16crxkid)
The easiest way is to fill them with for example screw or bolt.
Old Mar 21, 2005 | 07:01 AM
Chase's Avatar
Default Re: removing charcoal canister...... (Twilight)
Can i just remove the orange-ish hose from the firewall?? Should i just plug up the TB nipple thing?
Surewin's Avatar
Plug the black hose. Or remove the purge solenoid.
Leave the red hose open, your gas tank has to vent some how.
Cap the port on your throttlebody.
Old Mar 21, 2005 | 07:02 AM
91civicDXdude's Avatar
the orange hose is your fuel tank vent. the smaller vacuum hose is purge solenoid. you can remove the solenoid and plug the nipple on the intake manifold where the other vacuum line attached to it is attached to the manifold.
Old Mar 21, 2005 | 07:18 AM
Chase's Avatar
Default Re: (91civicDXdude)
Ok so basically i can remove the purge solenoid, and even the hoses attached to the bottom?
Old Mar 21, 2005 | 07:34 AM
brusk13's Avatar
Default Re: (b16crxkid)
any reason why your taking it out? there is safety to think about. and do everybody a favor and take that bolt out of the intake and buy a vacuum cap
Old Mar 21, 2005 | 07:37 AM
99sonicbluegsr's Avatar
Default Re: (brusk13)
what is the canister for anyway? i have always wondered
Old Mar 21, 2005 | 07:43 AM
Ash J. Williams's Avatar
Good, Bad…I'm the one with the gun
From: Trapped in time, Surrounded by evil, Low on gas
Default Re: (99sonicbluegsr)
the canister is to catch, store and slowly release fuel vapours back into the intake stream.
stan
Old Mar 21, 2005 | 07:52 AM
Chase's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by brusk13 &raquo;</TD></TR><TR><TD CLASS="quote">any reason why your taking it out? there is safety to think about. and do everybody a favor and take that bolt out of the intake and buy a vacuum cap</TD></TR></TABLE>
Im taking it out because i wanna clean my engine bay up and i live in Alabama where there's no emissions laws.
Old Mar 21, 2005 | 08:07 AM
ELAMINT5's Avatar
try and extend that red hose at least and put it where the old hose came out of the canister. Those are gas vapors and are flamable, be safe with it. I am considering this also. It just scares the **** out of me that it could ignite and go to the gas tank if not done right. I know it is a snow ***** chance in hell but IT COULD HAPPEN. I do not want to be a burned.
GOOD LUCK
Old Mar 21, 2005 | 08:13 AM
Chase's Avatar
Default Re: (ELAMINT5)
Thanks man, thats funny i was just thinking about extending it to the old canister dump spot right before i pressed refresh haha. I will prolly paint that red hose black or replace it so it wont be seen. Now im just contemplating headlight wiring to fenderwells, but im just a little freaked out. Wiring isnt my best thing
Old Mar 21, 2005 | 08:36 AM
ScottEK's Avatar
Just a note to all of you people doing this, if you do plug that line and for some reason disconnect your fuel return when you are working on your car there is a possibility that the fuel will start coming out the return.
When I was doing a swap, the temperature went from really cold to really hot and I came home to a lake of gas all over my garage floor.
Old Mar 21, 2005 | 08:41 AM
Chase's Avatar
Default Re: (ScottEK)
What if you just vent it to the old place like me and ELAMINT5 were talking about, would fuel come out the return line ?
and again i ask.....basically i can remove the purge solenoid, and even the hoses attached to the bottom??
Old Mar 21, 2005 | 08:53 AM
crxgator's Avatar
no body wanted to answer my question on this...what happens if you take the red line from the fuel tank and put it to the throttle body directly? where the other red hose use to be?
Old Mar 21, 2005 | 09:03 AM
Chase's Avatar
Default Re: (crxgator)
damn good question i dunno, i guess fuel vapors into Intake mani. hehe.
Old Mar 21, 2005 | 09:17 AM
Surewin's Avatar
I don't think your two-way valve (regulates gas tank pressure) would work properly if you connected the red hose to the throttle body.
Old Mar 21, 2005 | 10:48 AM
crxgator's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16crxkid &raquo;</TD></TR><TR><TD CLASS="quote">damn good question i dunno, i guess fuel vapors into Intake mani. hehe.</TD></TR></TABLE>
thats what i thought...but i got a response in the auto-x forum, "are you serious? "
Old Mar 21, 2005 | 11:27 AM
kid-honda's Avatar
Get a newer TB with a built in map and that whole firewall assembly can hit the garbage, the evap will not toss a code unpluged.
I dont see why you couldnt vent the tank right back into the manifold, thats what is does its just the charcaol canister is like a cat on a exhaust, it cleans it up a bit.
Or hang a line to vent it down to the ground out of the bay.
Old Mar 21, 2005 | 11:50 AM
Surewin's Avatar
Default Re: (kid-honda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kid-honda &raquo;</TD></TR><TR><TD CLASS="quote"> the charcaol canister is like a cat on a exhaust, it cleans it up a bit.</TD></TR></TABLE>
Cleans what? Gas fumes can be cleaned? The canister is a storage unit.
Old Mar 21, 2005 | 12:17 PM
N1ghtM0nkey's Avatar
Mine dosn't even have the hose on it, it's just venting directly into the engine bay. Probably not the safest thing but I've had no trouble so far.
Old Mar 21, 2005 | 02:58 PM
crexer's Avatar
Default Re: (N1ghtM0nkey)
i've done all this also and actually used a small nail to plug the TB nipple, where are you guys finding those vacuum caps? Do they just sell a misc. pack of those at the parts store?
Old Mar 21, 2005 | 02:59 PM
crxgator's Avatar
Default Re: (crexer)
yeah, autozone would have em next to the vacuum ts...
YoungKadafi
17
Jul 14, 2012 10:44 AM
949
11
Aug 22, 2009 11:58 AM
2001integra
Jun 11, 2008 08:52 PM
Slidin'Sidewayz
Honda Motorcycles
May 10, 2008 02:36 PM
mc
Oct 21, 2004 12:39 PM
