Finishing up swap. Have a few questions
I swapped a D15B into my 92 dx. The old intake mani had a purge solenoid on it. I can't find it if its there. So do I just leave that plug hanging on the harness?
By the charcoal canister there is a hose that has nothing hooked up to it...not sure if that is suppose to be like that or I disconnected it by accident while moving stuff around. I can't find where it hooks up if it goes anywhere
TIA
TIA
the jdm motor won't have hookups for the charcoal canister. usually, one line goes from the top of the TB to the canister, and one goes from the canister to the evap purge solenoid, which connects to the IM. you'll be fine running without the the canister. just leave the plug for the purge solenoid taped up, and you can remove the canister assembly completely if you cap offf al the lines
Tad
07-03-2004 02:12 AM
