90 integra ecu in eg
Old Mar 21, 2005 | 06:39 AM
jessej's Avatar
Default 90 integra ecu in eg
I have a frankenstein motor and it originally was in an 91 integra with cable tranny. Once installed in my 99 hx the only problem is the vs sensor. I was wondering if I could use the integra wiring and ecu in my civic since he had the motor running correctly in his car. Since mine has constant vtec and stops at 6k rpms. Would it not be like a obd conversion.
Old Mar 21, 2005 | 07:46 AM
jessej's Avatar
Default Re: 90 integra ecu in eg (jessej)
p
Old Mar 21, 2005 | 10:12 AM
hybridej7's Avatar
what kind of motor is it from the 91 integra? a gsr motor?
Old Mar 21, 2005 | 07:34 PM
jessej's Avatar
Default Re: 90 integra ecu in eg (hybridej7)
98 crv block, with 99 jdm b16 a head
Old Mar 22, 2005 | 04:37 AM
hybridej7's Avatar
you would have to use an obd-0 to obd-1 conversion and use an obd-1 vtec ecu. might get some codes for map sensors or something, not sure.
BIGef
Aug 22, 2012 06:31 AM
teets1888
Jan 5, 2008 01:36 PM
Crazykl3pto
10
May 12, 2006 08:20 PM
jvonb
Nov 13, 2005 02:02 PM
04falcon
Nov 23, 2004 11:38 PM
