CHeck my spark plugs
I checked my plugs yesterday, what do you think? I was surprised that all the plugs were a bit loosen, not too much, but definatelly not absolutelly tight. My ITR is stock, it's about 20000 miles on them (except of the right one that has only 2000 miles).
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DutchITR1689 »</TD></TR><TR><TD CLASS="quote">number 2 is rusting, is water getting in there?</TD></TR></TABLE>
I don't know, but for the same reason, I replaced the right plug 2000 miles ago. Now another plug is rusty. I found no water there
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by petrv »</TD></TR><TR><TD CLASS="quote">I don't know, but for the same reason, I replaced the right plug 2000 miles ago. Now another plug is rusty. I found no water there
You are just fine
</TD></TR></TABLE>You are just fine
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BLUE EH3 »</TD></TR><TR><TD CLASS="quote">what does oily plugs mean?</TD></TR></TABLE>
maybe a valve cover seal is leaking?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LsVtec92Hatch »</TD></TR><TR><TD CLASS="quote">Those plugs look like the engine is running lean to me...</TD></TR></TABLE>
yeah i agree, u should probably turn up your fuel pressure.
possibly...but sometimes they look like that if the car was driven hard recently. Id say those look like typical used ITR plugs.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RTW Ryan »</TD></TR><TR><TD CLASS="quote">
possibly...but sometimes they look like that if the car was driven hard recently. Id say those look like typical used ITR plugs. </TD></TR></TABLE>
You are probably right. My ITR is my fun weekend car, so it's mostly driven hard and often on a race track.
What he was saying though, is they should only look like that if driven very hard very recently. The heat that is a byproduct of 'hard' driving causes the mixture to lean out some as combustion chamber and underhood temps rise.
If you drove @ a track event , then had the vehicle shut down for a few hours, then drove leisurly home, the plugs should have returned to their normal state.
When i said your plugs look lean, i only meant very very slightly, nothing to worry about, but it is noticeable.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LsVtec92Hatch »</TD></TR><TR><TD CLASS="quote">What he was saying though, is they should only look like that if driven very hard very recently. The heat that is a byproduct of 'hard' driving causes the mixture to lean out some as combustion chamber and underhood temps rise.
When i said your plugs look lean, i only meant very very slightly, nothing to worry about, but it is noticeable.</TD></TR></TABLE>
Thanks for your suggestions, very appreciated
FYI, mine looks exactly like yours after 20.000 km. They are a bit white because of the advanced timing (18 deg). I'm now using NGK Iridium IFR7G-11K. Engine feels a little bit smoother.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BLUE EH3 »</TD></TR><TR><TD CLASS="quote">what does oily plugs mean?</TD></TR></TABLE>It could be spark plug o rings, If it's that then your in luck it's a piece of cake to fix.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by r573 »</TD></TR><TR><TD CLASS="quote">It could be spark plug o rings, If it's that then your in luck it's a piece of cake to fix.</TD></TR></TABLE>
April fools!
Huh?
April fools!
Huh?
cause I'm cheap
