b16 cams?
Old Jan 24, 2002 | 05:16 PM
wicked4u2c's Avatar
Default b16 cams?
Would a Civic SI 99-00 benefit from GSR Cams? I heard the GSR cams have longer lobs on them, is this true?
Old Jan 24, 2002 | 07:58 PM
VR6T's Avatar
Default Re: b16 cams? (wicked4u2c)
No.
Old Jan 24, 2002 | 08:35 PM
HaUTSaauce's Avatar
New User
no
Old Jan 24, 2002 | 11:28 PM
VR6T's Avatar
If you want to do a cam upgrade for a Civic Si, buy either Integra Type R cams or Civic Type R cams if you can find them. They're pretty much the same with the exception 3 degrees different duration on the middle lobe of the intake cam. They've been known to add quite a bit of power above 5600 rpm on the GSR and Si engines. They're well worth the upgrade in my opinion. Just be sure you buy the appropriate valve springs and retainers with them...
[Modified by VR6T, 8:28 AM 1/25/2002]
attack666
Apr 30, 2010 04:46 PM
iamthefollower
Jan 5, 2010 10:32 AM
GWInquisitor14
Sep 7, 2005 06:25 AM
91b16civic
May 13, 2003 04:26 AM
1996GsrVtec
Jun 14, 2002 12:07 PM
