The Weight thread
Old Mar 20, 2005 | 06:48 PM
leaftye's Avatar
Default The Weight thread
I'd like to start a thread like this:
http://forums.corvetteforum.co...84927
I started that thread so I can eventually build my Corvette into a racer. If you check that thread, you'll see that I've gathered lots of information, some of which I obtained myself. I'd like to do the same with my CRX as well. When it comes down to it, the Corvette costs a hell of a lot to race, and a hell of a lot more to **** up on, so I'd like to start building up the CRX. On the CRX I don't mind stripping it to the core, experimenting, and occasionally breaking things.
Anyway, I want to know how much everything weighs...from the cigarette lighter to the front fenders. I need to know the model (HF/Si) of the car and the year. If you find the information online, please post the link where you found it. If you weighed the part yourself, please post that too. I'll continually update this thread as I do with the Corvette thread. While I haven't posted any weights yet, I'll post what I find from searching the Archive...89 threads... Thanks!
FWIW, I'll probably race my CRX in SMII or whatever class the SCCA will let me run in....I don't care, I just want to have cheap & legal fun.
Eugene
Old Mar 20, 2005 | 07:06 PM
CRX_Control's Avatar
Default Re: The Weight thread (leaftye)
This is from my bathroom scale...and I weighed the **** in my room .
-crx 88 door w/o mirror ..........52 lbs
-si sunroof .............................24 lbs
-door mirror............................3 lbs
-front bumper support............15 lbs
-D series starter......................8 lbs
-HF transmission......................62 lbs
-dx transmission......................68 lbs
-hf exhaust manifold................. 8 lbs
Thats all for now, ill add **** if i get more lying around.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doublethink &raquo;</TD></TR><TR><TD CLASS="quote">bump for a sick, actually tech related thread.
</TD></TR></TABLE> I like this idea
Old Mar 20, 2005 | 07:11 PM
doublethink's Avatar
Default Re: The Weight thread (CRX_Control)
Old Mar 20, 2005 | 08:58 PM
leaftye's Avatar
Default Re: The Weight thread (doublethink)
*sigh*
The 89 threads that the Search feature pulled up didn't really pull up much info...mostly guesstimates and WAGs. Here's what I found now, and I'm not very confident in these numbers. I need your help! With a community as large as this forum, I would hope I won't be providing the majority of the information...but will if I must.
https://honda-tech.com/zerothread?id=1162901
12.2 lbs - 85 Si wheels
11.4 lbs - 85 10-spoke wheels
https://honda-tech.com/zerothread?id=1010194
5 lbs - 2nd gen HF rear bumper support
25 lbs - 2nd gen Si rear bumper support
https://honda-tech.com/zerothread?id=1155126
5 lbs - rear side window
https://honda-tech.com/zerothread?id=933386
85lbs - Y80
84lbs - J1
https://honda-tech.com/zerothread?id=581472
13.5 lbs - Kosei K1 Racing 15x7"
https://honda-tech.com/zerothread?id=574843
~75 lbs - '88 Si tranny
https://honda-tech.com/zerothread?id=612280
~18 lbs - '90 Si flywheel
https://honda-tech.com/zerothread?id=509964
~18 lbs - Si flywheel
~19 lbs - Si flywheel
20 lbs - Si flywheel
7 lbs - Clutch Masters flywheel
https://honda-tech.com/zerothread?id=640519
~35 lbs - Stock 2G CRX hood with latch, insulation pad and squirters
http://www.wheelweights.net
17 lbs - '90 Si 14x5 wheel
If you have parts off of your car, please throw them on the scale!
Old Mar 26, 2005 | 08:06 PM
da9project's Avatar
da abs 33lbs
Old Mar 27, 2005 | 02:22 PM
eda6's Avatar
weighed on a refrigerant charging scale.
1st gen b16 iacv .81 lbs
1st gen b16 fitv .5 lbs
1st gen b16 intake manifold (bare) 10.13 lbs
1st gen b16 fuel rail (with dampener/harness protector) 1.31 lbs
1st gen b16 flywheel 17.25 lbs
88 style rear lca 3.88 lbs
DA fuel ine (filter to rail) .38 lbs
94 gsr coolant rail .69 lbs
94 gsr alternator 11.63 lbs
94 gsr water pump 1.69 lbs
94 gsr oil pick up tube .56 lbs
94 gsr oil pan 5.94 lbs
94 gsr o2 sensor .22 lbs
240 cc p&h/saturated injectors .19 lbs
Modified by eda6 at 3:41 PM 3/27/2005
Old Apr 3, 2005 | 12:32 PM
rsca_crx's Avatar
Default Re: The Weight thread (eda6)
bathoom scale- 91 crx si
seats/rails - 35 lbs each
radiator- 10 lbs
behind the seat stow box- 13 lb
all interior plastic/trim- 18 lb
jdm sir front bumper support- ~1.5lb
jdm sir rear bumper support- ~2.5 lb
chevy5412
Classic Hondas
May 1, 2010 07:15 PM
got dell
Group Threads
Dec 5, 2008 11:58 PM
spoolin turbo s
Nov 16, 2008 12:21 PM
FastAsleep
Oct 27, 2007 04:01 PM
