should i get this crx?
ok well i dont have pictures but i can explain it fairly good. it is a 89 dx. the car was originall white but is not painted bright yellow including the door jams but not the engine bay. the interiour is completely screwed. the dash is half way painted yellow and the door panels and all the interior is out. i have a nice dash out of a 91 hb that i will put in place of the old ome. it has clear projectors that i would swap with stock headlights. it has some kinda header but noe sure what kind. i have all the parts to do a mpfi swap. the 1/4's seem good, there is not rot that i can see and only a little bubbleing starting to happen where the bumpper meets up with the wheel well. i would need to change the tailslights b/c they are some altezza looking lights. i guess he had a problem with the car starting after he messed arould with some fuses while trying to fix the radio. all the fuses he changed to 10's. he was asking 400 but then went down to 350. so whens its all said and done it will probaly end up being 300. i will only be using this for a d/d after doing a mpfi swap. lmk what you guys think. thanks
get it get it get it.
fix it, then take care of it!
great daily driver for you and one less cracked-out ricey POS on the road
(ps hit the enter key once in a while
i too vote to get it, if you dont mind the shady paint job
i dont buy cars anymore that have had their paint messed with, cause I've messed enough with shady body work and I cant stand it... the price, however, is pretty low.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skribblez »</TD></TR><TR><TD CLASS="quote">i just bought my crx today for 500
1990 with str8 frame and body..only a small dent on driver side door
original motor and only 154k...haha..
shoo..i couldn't pass up this deal..</TD></TR></TABLE>
sweet
sweet
get it. Typically any CRX with a somewhat straight body and no collision damage is worth up to $700
Consider if you spend $400 on a good interior for it, spend $200 on a D series engine. You can sell it for $2200+ on ebay...
money earned.. if the resale is there, your answer is always yes.
Or if you just love CRX's and have money to spend, just buy it and fix it up alot for the hell of it.
money earned.. if the resale is there, your answer is always yes.Or if you just love CRX's and have money to spend, just buy it and fix it up alot for the hell of it.
STHPERFORMANCE
Dec 24, 2002 03:51 AM
j/k
