What clutch for this....
92 si, d16z6, intake, header , exhaust, replacing my act HD pressure plate and exedy organic street disc after 20k
started to slip while crusing than slipped up a hill..... didnt even abuse it much at all... i want something that will withstand spirited driving and the occasional burn out.... and last more than 20k btw its not my driving
im pro
my mechanic says that if it doesnt look abused it was probably a defect and theres no warranty... should i just use the same stuff or get something stronger/less streetable... any help would be nice especially if you have a similar setup!
started to slip while crusing than slipped up a hill..... didnt even abuse it much at all... i want something that will withstand spirited driving and the occasional burn out.... and last more than 20k btw its not my drivingim pro
did your break in your clutch? right? and also did u get your flywheel resurfaced or get a new one? can play a major roll in clutch life, i say go with a stage 2 anything, and break it in right.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SantaCruz92Si »</TD></TR><TR><TD CLASS="quote">what abouy the centerforce II?
can get a good deal on it....
im buying a centerforce II from somone on this site for 100 bucks, its used for 1000 miles and come with everything and a new throw out bearing.
just search and search.
hanks for posting.... do i need to resurface my prolite flywheel that has about 20k on it? im throwing in the centerforce 2 and was also wondering if its stronger than the act organic street disc.... cant find good power holding claims....
SPOON_BeIgHtEeNsEe
Jan 22, 2003 08:18 PM
