Valve cover pressure!! Is this normal??
Old Mar 20, 2005 | 04:40 PM
pwrofdrm's Avatar
Default Valve cover pressure!! Is this normal??
Don't know if anyone can help me, but figured it's worth a shot...Is it normal to be able to feel wind pressure blowing out your valve cover breather? I took the hose off of my intake today and noticed that there was substantial wind pressure coming out of it, just wanted to make sure it's normal. The reason I am concerned is that my VTEC solenoid seal is leaking, and I'm thinking maybe it could be because there is more pressure in the head than normal? Yeah, I'm paranoid, I like things to be perfect .
I have seen on some crazy setups on here, and I noticed people had drilled holes in the front of their valve covers and attatched fittings to them, and ran hoses into a catch can. Is this the solution to this problem? Think I may try it just to be on the safe side. Anyone have a write-up? Thanks in advance
Old Mar 20, 2005 | 05:03 PM
Chase's Avatar
Default Re: Valve cover pressure!! Is this normal?? (lax1185)
its cool man, thats what its there for...to vent blowby gases out. You only need the two hoses in the front if u have like...crazy built motor.
Old Mar 20, 2005 | 05:04 PM
EP3_05's Avatar
That is why it is called a breather so it vents the pressure from the engine. The reason people use a small filter or catch can setup is to prevent the oil that is in the air from being sucked back into the intake system like the stock setup does.
Old Mar 20, 2005 | 07:07 PM
doublethink's Avatar
the catch cans are for the PCV valve system.
if you throttle the engine you will feel pressure from the breather.
you have a shop in suffolk county, where at?
Old Mar 21, 2005 | 07:06 PM
pwrofdrm's Avatar
Default Re: Valve cover pressure!! Is this normal?? (doublethink)
Okay good stuff, thanks for the help
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doublethink &raquo;</TD></TR><TR><TD CLASS="quote">
you have a shop in suffolk county, where at?</TD></TR></TABLE>
Rt. 112 in Medford. http://www.savageautosports.com is the site, under construction though, as I'm doing it myself in my spare time
Rikaro
Mar 11, 2009 01:25 AM
jfruauff
Nov 19, 2006 10:30 AM
Acura_I-RS
Oct 25, 2005 01:55 PM
ludelvr
Apr 27, 2004 08:51 AM
