hey u guys were is the Maintenance required light buttom to reset it
Old Mar 20, 2005 | 04:34 PM
94IntegraLs04's Avatar
Default hey u guys were is the Maintenance required light buttom to reset it
i have a 94 ls i wanna were is tht stupid buttom cuz it keeps blinkin after i start the car an i just change the oil 2 days ago.
Old Mar 20, 2005 | 04:42 PM
darkblue1998ls's Avatar
Default Re: hey u guys were is the Maintenance required light buttom to reset it (94IntegraLs04)
Mine is right under the dash on the driver side even with the gas pedal but right at the edge of your panel cover below the steering wheel.
Old Mar 20, 2005 | 04:48 PM
Default Re: hey u guys were is the Maintenance required light buttom to reset it (darkblue1998ls)
so wut i do just press the buttom an thts it
Old Mar 20, 2005 | 05:01 PM
jin_gsr's Avatar
throw key into ignition switch, press and hold down button, turn key to start, and hold for a few seconds until light goes off, yuh
Old Mar 20, 2005 | 05:06 PM
sabotage7's Avatar
read
Old Mar 20, 2005 | 05:08 PM
Default Re: hey u guys were is the Maintenance required light buttom to reset it (sabotage7)
thnx guys tht **** was scarin the crap out of me
Old Mar 20, 2005 | 05:11 PM
sabotage7's Avatar
no problemo! see, its not scary, just annoying!
Old Mar 20, 2005 | 06:56 PM
IggyBcool's Avatar
since we got this taken care of, i do have a question about the MR.. my cousins gsr isn't throwing any codes but his MR light is on. we've kind of came to the conclusion that its his gas cap. could his gas cap be causing it to throw the MR??? (not trying to steal the thread)
Old Mar 20, 2005 | 07:19 PM
Taristin's Avatar
Maint Req comes on at certin mileage points....
Old Dec 28, 2005 | 08:22 PM
ase2's Avatar
Default Re: (Taristin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Taristin &raquo;</TD></TR><TR><TD CLASS="quote">Maint Req comes on at certin mileage points....</TD></TR></TABLE>
just did a tune up two weeks ago and the light just came on three days ago. miles on the engine are 160xxx, so is this normal or do i gotta check whats wrong?
Old Dec 28, 2005 | 09:37 PM
DC2TEGGA-GSR's Avatar
like they said before, it comes on at certain milages, as long as his car isnt acting up, just reset it like you did yours
Old Dec 28, 2005 | 10:25 PM
jBj's Avatar
jBj
Default Re: hey u guys were is the Maintenance required light buttom to reset it (DC2TEGGA-GSR)
If your CEL comes on you have something to worry about and look into,
Not your Maint. Req. light, as stated its just a reminder of oil changes and the like.
Old Dec 29, 2005 | 06:52 AM
nsxtasy's Avatar
H-T Order of Merit
A picture is worth a thousand words:
Old Dec 29, 2005 | 08:06 AM
backlash's Avatar
Default Re: hey u guys were is the Maintenance required light buttom to reset it (nsxtasy)
Nice diagram nsx
Old Dec 29, 2005 | 10:31 AM
95SE 4DR's Avatar
GREAT INFO thank you
Old Dec 29, 2005 | 06:19 PM
ase2's Avatar
Default Re: hey u guys were is the Maintenance required light buttom to reset it (CayArellano)
i couldnt find it on my car?
Old Dec 29, 2005 | 08:32 PM
LowTEC-JERMZ's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CayArellano &raquo;</TD></TR><TR><TD CLASS="quote">GREAT INFO thank you</TD></TR></TABLE>
what he said i found mine
Old Dec 30, 2005 | 12:01 PM
ase2's Avatar
any help?
Old Dec 30, 2005 | 12:05 PM
tegbooster's Avatar
Default Re: (ase2)
see that panel you have....it's actually mounted on the back of that panel...so you have to reach your hand underneath and hook it back....or just get on ur back on the floor and you should see a little blue button
Old Dec 30, 2005 | 12:11 PM
dc2nick's Avatar
Default Re: (tegbooster)
dont go by color.... mines green.....
right where you took that picture... its BEHIND that pannel. its a the only box mounted to the back side of that pannel btw..
Old Dec 30, 2005 | 12:21 PM
nsxtasy's Avatar
H-T Order of Merit
Default Re: (dc2nick)
This is not complicated.
You DON'T have to be looking at it, so you DON'T have to worry what color it is. And you DON'T have to bend down to find it.
Just sit in the driver's seat, and reach down directly underneath the ignition key. Feel around behind the bottom edge of the panel for a square plastic piece. The button is in the center of that piece. Hold it down while starting the car and the light, instead of flashing, will stay on for a couple of seconds (constantly), and then go out.
Old Dec 30, 2005 | 02:11 PM
ase2's Avatar
got it, thanx
Old Jan 2, 2008 | 01:20 PM
EpicKills's Avatar
Banned
Default Re: (ase2)
Mine is green too. And it's very easy to find, it's behind the plastic, it's not visible while sitting upright. Thanks a lot, I got mine off now.
But Now i have questions. Does the MR light only come on when your car should need to be checked out or does it go off when a sensor says something is wrong?
Old Jan 2, 2008 | 01:34 PM
mrdeadman's Avatar
They let me pick
Default Re: (EpicKills)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EpicKills &raquo;</TD></TR><TR><TD CLASS="quote">Mine is green too. And it's very easy to find, it's behind the plastic, it's not visible while sitting upright. Thanks a lot, I got mine off now.
But Now i have questions. Does the MR light only come on when your car should need to be checked out or does it go off when a sensor says something is wrong?</TD></TR></TABLE>
It goes off about every 7500 miles.
Old Jan 2, 2008 | 01:43 PM
TomsDC's Avatar
Dealer told me its a really generic oil change reminder light that dont work all that well.
