oooops .. i thought my honda had no torque
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rcoolb2002 »</TD></TR><TR><TD CLASS="quote">
Now how did that happend
Why don't you tell us...
</TD></TR></TABLE>Why don't you tell us...
yeah, you basically just posted useless pictures.
We dont know your setup, axles, all i Know is you have a red civic with BFG drag radials.
But based on the information you gave us I'd say: The axle snapped because it was over-stressed beyond its limits.
Stupid question stupid answer
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JUN EK9 »</TD></TR><TR><TD CLASS="quote">yeah, you basically just posted useless pictures.
Stupid question stupid answer</TD></TR></TABLE>
Retorical question obviously. If I have a car that can snap axles, I more than likely know WHY it snapped the axles. I can't post an experience? Or am I in the wrong forum.... Looks to me like it says "eg + civic" which is definitely what category i fall into. My car is a honda.... Whats the problem?
I agree. This is a more like a ,"wow i snapped an axle and want to show it off" more than an informative thread.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg cookiemonster »</TD></TR><TR><TD CLASS="quote">I agree. This is a more like a ,"wow i snapped an axle and want to show it off" more than an informative thread.</TD></TR></TABLE>
Exactly .. its not informative at all, wasnt meant to be informative, and never will be informative. Unless to say not to use stock GSR axles with BFG's @ 13psi, and launch @ 7k.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rcoolb2002 »</TD></TR><TR><TD CLASS="quote">Exactly .. its not informative at all, wasnt meant to be informative, and never will be informative. Unless to say not to use stock GSR axles with BFG's @ 13psi, and launch @ 7k.</TD></TR></TABLE>
read the rules or better yet, let me post them for you.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">Mission Statement:
This forum is for the discussion of TECHNICAL issues for any 1992-up Civic (except for the 02-up Civic Si) and any 1993-1997 Del Sols. The primary goals of this forum are for people to gather useful technical information regarding said vehicles.</TD></TR></TABLE>
thats why they made the appearance forum. class of 2004
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg cookiemonster »</TD></TR><TR><TD CLASS="quote">read the rules or better yet, let me post them for you.
Good deal. I figured since this forum is under "model specific" and not "technical" .. that a non-tech artical could slide in under a secondary goal. Since of course the primary goal is to provide enlightening for those unenlightened.
</TD></TR></TABLE>Good deal. I figured since this forum is under "model specific" and not "technical" .. that a non-tech artical could slide in under a secondary goal. Since of course the primary goal is to provide enlightening for those unenlightened.
ok well instead of argueing and trying to be right, how about you tell us what you were doing when the axel snapped as well as what kind of motor and axels you have........Dont you think that would be a good start instead of saying uhh yeah my axel snaped how did that happen..........obviously because your running with stock axels and midrange torque????? maybe??
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DailyBlown »</TD></TR><TR><TD CLASS="quote">you need a new tire</TD></TR></TABLE>
Yeah they are about shot! Still good grip at the track though.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civichatch6989 »</TD></TR><TR><TD CLASS="quote">i was there on friday, did u see the primer crx with the 18's y0? </TD></TR></TABLE>
Where the wheels white? Or am i thinking of another car.
wow, you need to learn how to work on cars better....
only the lower ball joint and the lower shock fork bolt need to be removed to take out the axle....you just about took your whole front end apart!~
yeah you don't pullout axles that way takes too much time.
your tires explain everything
you are lucky your diff didn't break yet
another though is that your axle boot was ripped for a long *** time. cv joint got seized up and broke your axle.
Modified by ABK at 3:07 AM 3/21/2005
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Evs-One »</TD></TR><TR><TD CLASS="quote">wow, you need to learn how to work on cars better....
only the lower ball joint and the lower shock fork bolt need to be removed to take out the axle....you just about took your whole front end apart!~</TD></TR></TABLE>
my thoughts exactly
my thoughts exactly
