ATP fittings
Does anybody what kinda of metal is the 1/2 to -10An fitting? I"m having a tough time trying to tig it onto the oil pan. I put a magnet on it to see if it's brass and it's not. Thank you.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Krabbypro »</TD></TR><TR><TD CLASS="quote">I put a magnet on it to see if it's brass and it's not. Thank you.</TD></TR></TABLE>
If it's magnetic that will tell you it's a ferritic metal (some stainless steels, most mild steels).
If a magnet doesn't stick to it, it's most likely aluminum.
If you can't tell the difference between materials, I'd suggest not welding that yourself unless you want problems down the road.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Krabbypro »</TD></TR><TR><TD CLASS="quote"> I"m having a tough time trying to tig it onto the oil pan. </TD></TR></TABLE>
If your trying to weld alumium to steel, thats your answer... no weldy
Rich
Rich
My oilpan is steel, not aluminum. I thought all stainless steel were not suppose to be magnetic? The fitting is coated, but I brushed the color off prior to welding. I need help since this is the only thing that is keeping me from finishing my project.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Krabbypro »</TD></TR><TR><TD CLASS="quote">I thought all stainless steel were not suppose to be magnetic? </TD></TR></TABLE>
400 series is a great example of magnetic stainless steel.
