broken block
Old Mar 20, 2005 | 02:28 PM
b18cjdmwhore's Avatar
Default broken block
I had a broken itr block that i had rewelded.It was broken from the oil pan, through where the ac compressor bolts up, all the way up to the oil pump. Now it leaks a little oil from the oil pan. Any suggestions on how to fix???
Old Mar 20, 2005 | 05:10 PM
fulldragcrx's Avatar
Default Re: broken block (b18cjdmwhore)
is it leaking from the oil pan gasket, or the welded area? check for warpage and then repost your findings.
Old Mar 21, 2005 | 08:38 AM
mrDFWmechanic's Avatar
just replace the gasket and put some silicone on too
Old Mar 21, 2005 | 10:00 AM
SJcivic's Avatar
Default Re: (iROCKtheSOHC)
obviously a new block would be the sure-fire way to go, but if you clean the crap out of the area thats leaking, replace the gasket, and use rtv it should hold (if its by the pan). If its by the AC, then expoxy is the low-cost fix.
Rich
Old Mar 21, 2005 | 02:14 PM
I just change the gasket and got a new oil pan my wasn't pretty. Thanks for your guys help will try some rtv.
Old Mar 21, 2005 | 04:51 PM
mike_belben@yahoo.com's Avatar
From: not riding any bandwagons in, massachusetts, usa
devon f-2 epoxy
CRVinsoCA
Sep 10, 2010 01:17 PM
Kronn 98SH
Mar 25, 2009 12:40 PM
Corporation
Sep 1, 2005 09:11 PM
mf RENO
Aug 31, 2004 11:06 AM
JMinSi2000
May 18, 2002 10:02 PM
