!!!!!!!!!!!! Fuel Problem :(
Old Mar 20, 2005 | 02:28 PM
the niz jiz's Avatar
Default !!!!!!!!!!!! Fuel Problem :(
i have a 91 crx hf, 88 dohc zc, my problem is, i cant get my car to stay on...it'll crank over and stay on for like 5-10 seconds with Starter fluid....i checked my fuel pump and its fine...im gettin fuel to the fuel rail and i cleaned out my fuel filter, i checked my injectors and only like 2 was shooting, but it was light...so i got my injectors from my d15 and put it on....but its only shootin a little bit...is it suppose to only shoot alittle or alot??? Please help because im stumped.. i have no idea whats wrong with it...
Old Mar 20, 2005 | 03:03 PM
Malgerus's Avatar
Default Re: !!!!!!!!!!!! Fuel Problem :( (N.O.R.E)
Just because you're getting fuel doesn't mean that you're getting enough> Consider installing a cheap B&M fuel pressure guage. You should be getting 30-38 PSI of fuel pressure or so with the car off - just when you prime the pump.
Old Mar 20, 2005 | 03:04 PM
ne1
Old Mar 20, 2005 | 03:10 PM
Malgerus's Avatar
I just told you what you should do. Why not try it?
Old Mar 20, 2005 | 03:23 PM
Default Re: !!!!!!!!!!!! Fuel Problem :( (Mr. S)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr. S &raquo;</TD></TR><TR><TD CLASS="quote">I just told you what you should do. Why not try it?</TD></TR></TABLE>
yeah i post that like the same time sorry, but ima try that thanks
also if im gettin less then what i should how do i fix it?
Old Mar 22, 2005 | 11:10 AM
i just changed my resistor box and checked my main relay everything looks fine...with the new resistor box it'll crank over for like a second without no starter fluid...injectors still shoot but still alittle bit.....should i just change my injectors???? or if theres another problem please let me know......
Old Mar 22, 2005 | 12:59 PM
also i looked at the zc wirin harness and theres and extra plug that my old d15 dont have...would that cause a problem?? (im using the same wiring from the hf)
Old Mar 22, 2005 | 01:50 PM
88cerx's Avatar
did you just do the swap or anything else to the motor befor this happened. sound like injectors are working not much feul comes out upon start on a relitvaly stock motor. check your timing belt that would not run rite if its off a tooth or 2 give more info on how the problem started
Old Mar 22, 2005 | 01:54 PM
Malgerus's Avatar
Default Re: !!!!!!!!!!!! Fuel Problem :( (88cerx)
It's not going to be your injector resistor box. I've never heard of anyone frying those. It's also probably not your injectors. I would say it's a fuel pump problem, but I highly reccomend getting that guage before you go to the trouble of replacing the fuel pump (BIG pain in the ***).
Destructive-
Mar 5, 2011 01:36 PM
WheaMyRyceGo
May 31, 2009 04:37 PM
cyrix12
32
Oct 24, 2006 07:42 AM
existanzcivicb20
Apr 20, 2006 09:23 PM
lsvtecna
Mar 25, 2006 06:47 PM
