stripped lower ball joint ?
Old Mar 20, 2005 | 02:03 PM
menkio's Avatar
Default stripped lower ball joint ?
Odd.. i was working on some things and put my lca on the hub, put the castle nut on and started turning, then got the rachet and turned.. i still have plenty of tread but the bolt turns with the nut at a certain point. Also its not to the depth that i can throw in a cotter pin.
i'll add a picture so people will look at the thread. LOL
Old Mar 20, 2005 | 02:25 PM
FIGARILA's Avatar
Default Re: stripped lower ball joint ? (menkio)
put a pickle fork in between the the castle nut and the the bottom of the spindle and apply presure. you want the pitman arm to wedge it self still while you remove it and clean the threads or tighten it a bit past those rough threads.
Old Mar 20, 2005 | 02:27 PM
EG6 SiR's Avatar
Just get a jack and lift the control arm until its really snug against the hub. That will stop it from turning so you can tighten it.
Old Mar 20, 2005 | 02:30 PM
menkio's Avatar
Default Re: stripped lower ball joint ? (EG6 SiR)
ohh yea i forgot it kinda presess itself it, tappered or what not, thanks for the help guys
Old Mar 24, 2005 | 09:28 PM
ScottEK's Avatar
NELSON: HA HA
You suck at working on cars.
Now that I'm done acting like how you usually post I'll tell you how to fix it. Get a tap set, chase the thread. The castle nut will go right on and you'll be able to even torque it without doing anything goofy like trying to bind it up with a jack. Another plus is that if you do both the nut and the stud it will be 100x easier when ever you take it on / off in the future.
Old Mar 24, 2005 | 11:14 PM
ek hatchhh's Avatar
this happened to me 2 weeks ago! a balljoint was pretty cheap at autozone
Old Mar 25, 2005 | 01:18 AM
Andres-eh2's Avatar
i had to drop my tranny today so i went to remove the castle nut looking thing and it spun, after trying different vice grips etc, my uncle came out and just cut that ish! he's all about brute force, luckily i got a replacement.
Arent the balljoint going bad when they start spinning?
Old Mar 25, 2005 | 08:02 AM
ScottEK's Avatar
Default Re: (Andres-eh2)
No your threads are just rough. If you use an impact it will usually spin it fast enough that it drops off. Then just chase the threads and you're set.
Old Mar 25, 2005 | 08:05 AM
Kendall's Avatar
Depending upon how bad it is, sometimes you can just give it a good wack with a hammer and it tightens up.
Old Mar 25, 2005 | 08:55 AM
kleanlscivic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EG6 SiR &raquo;</TD></TR><TR><TD CLASS="quote">Just get a jack and lift the control arm until its really snug against the hub. That will stop it from turning so you can tighten it. </TD></TR></TABLE>
this is what i did, it finally got it i was tryin to get it right before nopi last year, put a new wheel bearing in it. finally cought on mine
Old Mar 25, 2005 | 09:36 AM
94eg!'s Avatar
#1 Super Guy
Loved
Default Re: stripped lower ball joint ? (kleanlscivic)
Replace the castle nut, and you won't have anything to worry about.
Jack up the LCA, and have someone push down on the brake disc while you torque down the nut.
Juans_MX3
42
Jul 10, 2021 04:38 PM
overurhead360
Mar 17, 2010 12:54 PM
speed_racer012
32
Mar 12, 2004 02:58 PM
ScottEK
17
Sep 21, 2002 06:23 PM
nugget8000
Aug 27, 2001 09:37 PM
