94 Prelude Seats in 5th Gen hatch
I just installed some 94 Prelude seats in my 94 hatch, and I have to say that these seats are bad ***! The bolsters are great, and the seating position is nice. I ended up using the prelude seat pans, sliders & rails, I just drilled the prelude bracket some, and i will need to make an extra bracket next weekend for the 4th bolt as only 3 bolts are holding them currently. I will most likely cut off part of the stock civic bracket & weld it to the prelude rail. The seats sit slightly lower in the *** portion, and about the same height for the legs due to the lower cushions contour/angle, but the feeling is a million times better!!
been awhile.. bump cuz i searched and this is what i was looking for!!!
btw: any pix? and detailed write up? i'm currently undergoing the same seat swap!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DJ_SaNdOz »</TD></TR><TR><TD CLASS="quote">I just installed some 94 Prelude seats in my 94 hatch, and I have to say that these seats are bad ***! The bolsters are great, and the seating position is nice. I ended up using the prelude seat pans, sliders & rails, I just drilled the prelude bracket some, and i will need to make an extra bracket next weekend for the 4th bolt as only 3 bolts are holding them currently. I will most likely cut off part of the stock civic bracket & weld it to the prelude rail. The seats sit slightly lower in the *** portion, and about the same height for the legs due to the lower cushions contour/angle, but the feeling is a million times better!!</TD></TR></TABLE>
On my prelude seat, i just swaped out the 5th gen civic rails and they fit perfectly...bump for great seats...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by igone916 »</TD></TR><TR><TD CLASS="quote">
On my prelude seat, i just swaped out the 5th gen civic rails and they fit perfectly...bump for great seats...</TD></TR></TABLE>
just hoping its the same for a 92 hatch tho.. all you had to switch were the rails? how easy is that?
The_Head
Sep 1, 2004 09:33 PM
