B18a build
Old Mar 20, 2005 | 12:53 PM
91ls-v's Avatar
Default B18a build
well i'm bout to buy some cams soon and was curious on what kind of compression ratio
the exospeed race ls cams need to gain as much power as possible and if it'll gain good power with stock compression ratio or should i juss get the ls909 from exospeed
it's almost the same price and i know both of them are regrind stock cams
i need some opinons
also are gsr valve springs and retainers useable with b18a head?
this is what i'm going to do
b18a block with p30 or pr3 pistons which ever i find cheaper
thinner headgasket
and i/h/e
should i get arp rod bolts?
what do you guys think of the set up, will i have any clearance problems with using the p30/pr3 pistons and what kinda power will i be looking at
Modified by 91ls-v at 2:48 PM 3/20/2005
Old Mar 20, 2005 | 12:58 PM
Grand's Avatar
as far as i know you cant use the gsr springs for pistons id go with p30 wich is around 10.8-11 compression
Old Mar 20, 2005 | 01:32 PM
91ls-v's Avatar
will i be able to run up to 8k rpm without damaging anything by using the gsr springs the springs currently have 120k miles on it or should i juss buy new ones?
Old Mar 20, 2005 | 02:48 PM
vart's Avatar
Default Re: (91ls-v)
u could just buy my crower 404s and call it a day
Old Mar 20, 2005 | 04:19 PM
Grand's Avatar
Default Re: (vart)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vart &raquo;</TD></TR><TR><TD CLASS="quote">u could just buy my crower 404s and call it a day </TD></TR></TABLE>
how much you want for them i might be interisted in them
Old Mar 20, 2005 | 05:18 PM
vart's Avatar
Default Re: (LG_R32)
check sig
Old Mar 20, 2005 | 06:00 PM
Steemo's Avatar
Default Re: (vart)
im running p30 pistons in my ls block making about 11:1 compression i wouldnt worry too much about getting a thinner head gasket. If you want more compression than that you could try flat faced valves. crower also makes some pretty good cams, i havent got around to getting my cams yet but the exospeed ones have sparked my interest. good luck with the build!
Old Mar 20, 2005 | 06:53 PM
91ls-v's Avatar
do you have any clearance issues with the p30 pistons?
t3601
29
Jan 24, 2011 01:35 PM
94gsr18kid
Feb 9, 2005 10:23 AM
the DA in HONDA
Jan 31, 2005 07:22 PM
qcktegls
16
Nov 10, 2004 08:04 PM
Ditdogs
Mar 17, 2004 06:32 PM
