d15 into 95 gsr
hey guys, what will i need to swap a d15 into my gsr? I want to pull my ls/vtec and do some work on it. I have a d15 here and i dont want any down time since my car is my daily driver. Thanks
wait, your doing this just so you can keep driving while you build your motor right?
you dont actually plan on running a d15 in a gsr do u?
coz that would be silly.
This has been done before. People put the least best thing in their car while building the next best. You dont need mounts. The civic mounts will work fine. Integra and civic/ Engine bay are the same, only the block and trans/mounts are different. The only thing you would need is the d15 ecu, shift linkage, and obvious stuff like the header and axles. The integra axles use the half shaft, the civic's dont.
As for the swap, Just laugh when you get smoked by a geo metro
The actual side mounts for integra's and civic's are identicle. Only the block brackets are different. The only mounts that you should need are the side transmission civic mount, and the rear engine civic bracket. The rear mount that connects to the car should be the same, so only the bracket has to be changed. Besides that, the a/c bracket if you chose to use it. And by the way, you will need a civic ecu. The fuel delivery for a 1.8 and 1.5 are not the same, and v-tec as well will justify the altercation. Just get the right ecu. I am actually selling some of the parts you may need. Take a look.
http://cgi.ebay.com/ebaymotors...61765
http://cgi.ebay.com/ebaymotors...67593
