Please describe this brake issue technical manner.
Pagids tend to do this, though it's in a much more even pattern. The pad is basically leaving bits of itself on the rotor to grip onto. Looks like you were over the temperature range of the R4S's though.
You'll have to cool it down somehow, or run real race pads.
Warren
Warren
It's called carbon tracking or carbon tracing. Believe it or not, a lot of the components in a brake pad are there to REDUCE the friction, to make the pad more progressive and last longer. One of the components often used is graphite or other similar forms of carbon. if the conditions are right, the carbon from the pad fuses to the cast iron of the brake rotor, resulting in what you show in your picture. It's easy enough to remove by taking some sandpaper to the rotors.
Wow, I'm supprised I still remember that from when I co-op'ed with Rabestos.
-Chris
-Chris
...it's a Volvo.
Volvo 4 wheel disc (since ~1966) ownz j00.
Per the ABS comment.... 1984 = non-ABS equipped 242.
Will
-who is thankful for all of the helpful comments
After much deliberation and frustration, I believe I have diagnosed your problem...
...it's a Volvo.
...it's a Volvo.
completely ownz j00!
I think the R4S pads I used at summit did this... I guess I would know for sure better if i didn't get down to the backing plates.. They worked a lot better with backingplate to rotor stopping power
...it's a Volvo.
Will
Will
thought I was staring at some funky wheel on your ITR.
Funky wheels on the Volvo = Ferrari units...
Per the I-6 turbo comment...
I can't keep brakes on a ~200hp I-4 turbo... How the puck will I be able to stop 600hp-700hp?
Will
me thinks that R4S's suxzor.
but don't throw them away either.
metal to metal =
Street use =
Track use =
Will
-who has learned better since that time
I can circle my 2600 lb Sentra approximately 3 times around VIR south with R4S pads before they give out. That track is just too hard on brakes to use anything other than R4, Panther +, or Hawk Blues.
The rotors on my Eclipe looked like that after Kershaw a few years ago.
nonbox
Sep 24, 2001 08:34 AM
nonbox
Sep 24, 2001 08:11 AM
