Ignition ON/ no power.
Last night i had this problem occured.
I turned my ignition on and the cluster lights would not lit.
I thought that it is the battery, but it wasnt as all the headlights and every other accesorry was working.
I turned the key to start the car, it started but instantly shut off.
I turned the key further on like when you start a car, just without starting.
Cluster lights lit, i turned the key back to the ignition ON position and the car started.
What do you guys think could be the cause of it?
I had a similar problem before and it was my main relay, i replaced it with a used one.
This time, it seems like i have a short somewhere as turning the key doesnt do anything until i turn it further on.
I have a video i just made, but the file is too big, i cant host it.
Can you guys give me any ideas about it ..
Thanks, any help is apreciated.
Here is the video if it helps.
Car shuts off closer to the end of the video.
http://www.we-todd-did-racing....E%3D
Modified by Groove_D at 9:22 PM 3/20/2005
