Causes of wheel hop?!?!?!
Old Mar 20, 2005 | 10:00 AM
.BigSexy's Avatar
most hood white kid
Default Causes of wheel hop?!?!?!
Ok...well me and my buddy decided to run our cars last night. We have similar setups..him-95 Ex w/ minor bolt ons, and me- 94 Dx w/ short ram intake. So we get out on a long straight highway at about 1:00 am, we went cruised the highway first to look for any unwanted on-lookers, so I we get next to each other, I am holding my revs steady at 4000 and he said he was at about 3500 when we ended the race, so we both launch, I have some minor wheel hop, but he has some major wheel hop, I mean I could hear it pretty bad. My question is what causes wheel hop and what is the solution to fixing it. I know there are probably multiple causes/solutions to this problem, but I wanted to get anyone and everyone's opinion/experences with wheel hop and what they did to fix it. But here is an even weirder problem, this is the second time he has dragged his car, and both times he launched, he blows the fuse to his corners/tails/instrument lights....what could be the cause of this?? Any and all comments are welcome
Oh and on a side note, he beat me by half a car
Old Mar 20, 2005 | 10:02 AM
jlacoy82's Avatar
71.192.16.183
Wheel hop + blown fuse = probably loose wire.
Old Mar 20, 2005 | 10:04 AM
.BigSexy's Avatar
most hood white kid
Default Re: (jlacoy82)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jlacoy82 &raquo;</TD></TR><TR><TD CLASS="quote">Wheel hop + blown fuse = probably loose wire.</TD></TR></TABLE>
ok...but what causes wheel hop?
Old Mar 20, 2005 | 10:13 AM
e jay one's Avatar
Default Re: (egcoupe94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egcoupe94 &raquo;</TD></TR><TR><TD CLASS="quote">
ok...but what causes wheel hop?</TD></TR></TABLE>
you dumping the clutch at 3500 rpm next time try to feather the clutch whell hop can break your axles too. just practice your launches and youll get it down.
Old Mar 20, 2005 | 10:14 AM
komat's Avatar
Default Re: (e jay one)
stiffer mounts and traction bar will help reduce it
Old Mar 20, 2005 | 10:40 AM
jlacoy82's Avatar
71.192.16.183
Default Re: (komat)
Actually some guy posted up on here a few months ago and had pictures of his motor from wheel hop: It snapped the mounting point for the engine mount clean off the block.
Old Mar 20, 2005 | 11:00 AM
Kyles ej1's Avatar
im guessin both of u were both at max psi and dumping it at 4k, that will definately give u wheel hop. try revving it to like 6k and slipping the clutch and stop street racing
Old Mar 20, 2005 | 11:25 AM
ironlung78's Avatar
Default Re: (komat)
stiffer motor mounts or motor mount inserts will cure it
**replaced mine last weekend and the drivers side front was shot**
Old Mar 20, 2005 | 11:27 AM
xxchinkzxx's Avatar
Default Re: (sidesi)
Doesnt tires have something to do with it?
Old Mar 20, 2005 | 11:29 AM
Kyles ej1's Avatar
Default Re: (xx*****zxx)
yea like i said, they were both probably at max psi cuz ive ben at 44 psi when i got wheel hop and then lowered it to like 30 cuz i forgot and no wheel hop
Old Mar 20, 2005 | 11:52 AM
jon volk's Avatar
My EP wheel hopped BAD. I picked up some motor mount inserts for just under $30 and it almost totally got rid of the hop.
Old Mar 20, 2005 | 11:57 AM
RedDC5's Avatar
Default Re: (k20 jon)
Check your mounts. There was one in front of my tranny where the screws seemed to work themselves out and that caused wheel hop on my car. We replaced it to the best of our ability and I felt a pretty noticeable difference and a loss of wheel hop.
Old Mar 20, 2005 | 12:00 PM
.BigSexy's Avatar
most hood white kid
what kind of motor mounts did ya'll buy?? I am at like 35 psi last I checked...I did kind of dump the clutch a bit, but like I said, mine wasnt as bad as his, his was like majorly bad....I would just like to do one of those nice lanches, nice and smooth, no wheel hop...but I guess I just have to practice
Old Mar 20, 2005 | 12:05 PM
RedDC5's Avatar
Hasport gonna have the best in my opinion, if you have the cheese. True, practice makes perfect, or at least a better launch, lol.
Old Mar 20, 2005 | 12:08 PM
.BigSexy's Avatar
most hood white kid
Default Re: (4door_ridin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4door_ridin &raquo;</TD></TR><TR><TD CLASS="quote">Hasport gonna have the best in my opinion, if you have the cheese. True, practice makes perfect, or at least a better launch, lol.</TD></TR></TABLE>
yeah...this was like only the 2nd or 3rd launch I have ever done...yeah hasport is hella expensive
Old Mar 20, 2005 | 01:36 PM
d15z6's Avatar
Default Re: Causes of wheel hop?!?!?! (egcoupe94)
I can not buy stuf from that fancy companies that you are all talking about so i just hawe to improvise. I find a guy that is working withy rubber and give him my original mount. He burned the rubber and put the new in a litle bit harder than original and the car runs great. I changed only the main mount a already reduced wheel hop drasticly.
Old Mar 20, 2005 | 01:43 PM
SL!M's Avatar
i think its called jimfab.com. they sell poly urethane motor mounts for an eg and they are cheaper than hasport
Old Mar 20, 2005 | 01:53 PM
Daniel's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egcoupe94 &raquo;</TD></TR><TR><TD CLASS="quote">ok...but what causes wheel hop?</TD></TR></TABLE>
Take from a mod on another site:
wheel hop is not caused by motor mounts. what happens is your tires pull your LCA's forward at take off, then they snap back during low traction situations causing the tire to "skip"
Old Mar 20, 2005 | 04:55 PM
.BigSexy's Avatar
most hood white kid
Default Re: (Daniel)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Daniel &raquo;</TD></TR><TR><TD CLASS="quote">
so what can fix this other than practice?
Old Mar 20, 2005 | 05:12 PM
jethawk's Avatar
http://www.summitracing.com
Part # PTP-8-1901
That Is If You Still Have Your D
Old Mar 20, 2005 | 07:15 PM
.BigSexy's Avatar
most hood white kid
d-series for life bitches
Old Mar 20, 2005 | 08:08 PM
platinum00's Avatar
Default Re: (jethawk)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jethawk &raquo;</TD></TR><TR><TD CLASS="quote">http://www.summitracing.com
Part # PTP-8-1901
That Is If You Still Have Your D</TD></TR></TABLE>
i have those and still have hop, they do help though..
your going to need a traction bar and better tires...
Old Mar 20, 2005 | 08:33 PM
Street Ghost's Avatar
Default Re: (platinum00)
Torque mount inserts and an LCON traction bar got rid of my wheel hop.
Old Mar 20, 2005 | 08:45 PM
.BigSexy's Avatar
most hood white kid
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by platinum00 &raquo;</TD></TR><TR><TD CLASS="quote">
how much do they help?
Old Mar 20, 2005 | 08:51 PM
J.D.M.'s Avatar
i have a problem with wheel hoppin without dumpin the clutch.. whenever i get in my car the first time of each day, and excellerate normally, i have wheel hop.. and no my tires aren't spinnin, but my climate control and **** are dancin.. what can be the cause of this.. same thing with motor mounts and ****?
