Suspension & Brakes Theory, alignment, spring rates....
Koni Yellows + Ground Control Coilovers
Old Mar 20, 2005 | 09:31 AM
kevin85193's Avatar
Default Koni Yellows + Ground Control Coilovers
I have koni yellows/gc coilover (OTS)/ and rear SRR LCA's and the car is aligned. I just got this done the other day.
I've tried a ton of settings, but it seems to still be bumpy. Bumpy meaning can't even talk on the phone when driving(passenger not me) and hitting your head on a semi decent bump.
I want it so it's less bumpy, would raising it back up fix the problem? Someone said if the bumpstops werent cut it could cause it to be bumpy
Old Mar 20, 2005 | 10:26 AM
Targa250R's Avatar
be professional
Default Re: Koni Yellows + Ground Control Coilovers (kevin85193)
What do you have the rebound set at?
That car is awfully low. Definitely a good possibility that you're hitting the bump stops . . . raising the car up and/or trimming the bump stops and/or buying a set of Ground Control extended-travel upper shock mounts could help.
If you raise the car up and it ceases to be extremely bumpy, you'll know you were too close to the bump stops.
I hope you got one of those "lifetime alignment" deals, because if you change the ride height it will need aligned again.
Old Mar 20, 2005 | 10:48 AM
kevin85193's Avatar
Default Re: Koni Yellows + Ground Control Coilovers (Targa250R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Targa250R &raquo;</TD></TR><TR><TD CLASS="quote">What do you have the rebound set at?
I hope you got one of those "lifetime alignment" deals, because if you change the ride height it will need aligned again.</TD></TR></TABLE>
yeah, I screwed myself over by not getting the lifetime alignment. I didn't have the money for it because I spent it all on the suspension and some things went wrong and I needed to spend more money. so, next time I'll have to get the lifetime alignment.
I also think I'm hitting them becuase I hear a clanking in the rear passenger side.
I'll look into Ground Control extended-travel upper shock mounts, thanks for the reply
btw: where can i found hte extended-travel upper shock mounts
Modified by kevin85193 at 2:59 PM 3/20/2005
Old Mar 20, 2005 | 11:22 AM
DaKINE-Ek's Avatar
From: So Cal where old pople try to race you, U.S.A
http://www.ground-control.com/
Old Mar 20, 2005 | 11:37 AM
awdriscol4's Avatar
Default Re: Koni Yellows + Ground Control Coilovers (DaKINE-Ek)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Targa250R &raquo;</TD></TR><TR><TD CLASS="quote">I hope you got one of those "lifetime alignment" deals, because if you change the ride height it will need aligned again.</TD></TR></TABLE>
Where can you get a 'lifetime alignement' deal???
Old Mar 20, 2005 | 11:47 AM
kevin85193's Avatar
Default Re: Koni Yellows + Ground Control Coilovers (awdriscol4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by awdriscol4 &raquo;</TD></TR><TR><TD CLASS="quote">
Where can you get a 'lifetime alignement' deal???</TD></TR></TABLE>
Firestone by me has it for $160 or i believe it might be $180
I think it's a pretty good deal if you bring the car back up during every winter ect
Old Mar 20, 2005 | 08:01 PM
EgRedSi's Avatar
Integ's are nice but I've always known them to be bumpy. Normally people (that I know) with sleeves and shocks have that problem. Myself, I have Teins, it's not bumpy but its really hard. The body of my car goes with the tire, potholes included. I think that it's not something that avoidable but it would be good if it was.
Old Mar 20, 2005 | 10:29 PM
eMpAtHy's Avatar
hrmm, im having a problem with clanking noises in the back too. rebound for my agx's are set at 3 with 4 max. i will try 4 tomorrow. but there was an amazing amount of clanking. even when i hit the smallest bumps. my car isnt as low as this integ either. i had a 2 finger gap all the way around.
Old Mar 20, 2005 | 10:38 PM
hayabusa160's Avatar
Default Re: Koni Yellows + Ground Control Coilovers (eMpAtHy)
my friends car with similar set up on his teg rides pretty damn nice.
possible u might have to trim the bump stop alittle. hes just as low as you.
when i got the h&r cup kit the instructions specifically said not to cut the bump stops. but then who knows lol all set up not the same.
Old Mar 20, 2005 | 10:57 PM
.water's Avatar
some place will not take u..cause ur car is on adjustble coils.oh well try it
iam talking about lifetime
Old Mar 21, 2005 | 09:45 AM
kevin85193's Avatar
Default Re: Koni Yellows + Ground Control Coilovers (Chris DC2)
firestone by me has one lift for lowered cars :0
Old Mar 21, 2005 | 12:17 PM
kevin85193's Avatar
hmm.. and to raise the coilovers, i just turn the **** with an allen key, right?
Old Mar 21, 2005 | 01:45 PM
DaZman69's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kevin85193 &raquo;</TD></TR><TR><TD CLASS="quote">hmm.. and to raise the coilovers, i just turn the **** with an allen key, right?</TD></TR></TABLE>
you loosen the screw with the allen key, then turn the big nut with a spanner wrench.
Old Mar 21, 2005 | 02:51 PM
kevin85193's Avatar
Default Re: Koni Yellows + Ground Control Coilovers (DaZman69)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DaZman69 &raquo;</TD></TR><TR><TD CLASS="quote">
you loosen the screw with the allen key, then turn the big nut with a spanner wrench.</TD></TR></TABLE>
ah, thanks!
Old Mar 21, 2005 | 07:02 PM
sabotage7's Avatar
you can also get the lifetime alignment thing at tire kingdom, thats where mines at. as far as the set up, i have koni yellows and GCs and havent had any problems, mine rides great. i got the konis set in the middle. if you do put them all the way on firm, the ride is very bumpy, so bad that it makes you wanna **** your pants! lol. i did, however, buy new bumpstops bc mine turned to dust and i cut them in half.
Old Mar 22, 2005 | 04:32 AM
kevin85193's Avatar
Default Re: Koni Yellows + Ground Control Coilovers (sabotage7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sabotage7 &raquo;</TD></TR><TR><TD CLASS="quote">you can also get the lifetime alignment thing at tire kingdom, thats where mines at. as far as the set up, i have koni yellows and GCs and havent had any problems, mine rides great. i got the konis set in the middle. if you do put them all the way on firm, the ride is very bumpy, so bad that it makes you wanna **** your pants! lol. i did, however, buy new bumpstops bc mine turned to dust and i cut them in half.</TD></TR></TABLE>
yeah, looks like i need to get new top mounts. Shitty because I'm broke right now and it isn't fun dealing with this...
Old Mar 22, 2005 | 06:32 PM
eMpAtHy's Avatar
i fixed my clanking. it was the top bushings. wasnt put on.
Ahh Vtec
Jun 28, 2008 11:13 AM
jimmhatch
Jan 6, 2008 07:54 PM
GSRintegra_Bob
Oct 31, 2005 03:13 PM
lak8
Aug 29, 2004 07:10 PM
