Which cam is ideal for my compresison?
Old Mar 20, 2005 | 08:45 AM
JinteDgraM's Avatar
Default Which cam is ideal for my compresison?
I've been doing some research and found lots of different routes....
My set up :
JDM p30 B16 I/HE
Skunk 2 IM,Stage 1 or stage 2 skunks,Supertech Springs and Retainers, ITR LMAs
Aasco 11.4 fly, Exedy Stage 1, CTR crank pulley
VAFC2
My plan was to get Skunk2 Stage 2s, but I can only get ~11.0 compression with milling the head 0.020 (OR thin headgasket). And if I cut that down too far, I might have valve/piston clearance issues. So, since I"ll pay the same amount for stage 1 skunks as I would stage 2s, Should I :
Continue with stage 2s - Dont worry about the 11.0 compressoin because the clearance will NOT be an issue, There will be MORE power still than stage 1s
OR
just get the stage 1s - more ideal for an easier obtainable compressoin (maybe modify the stock HG for 1-2 layer or a lighter mill OR get 11.0 again with 0.020 off if that would be best - NO clearance issues? and Very easy to tune.
Thanks for your help. I'm doing this build this week and need to know.
Brandon
Old Mar 20, 2005 | 08:56 AM
b20byJDMotors's Avatar
Default Re: Which cam is ideal for my compresison? (JinteDgraM)
im running skunk2 2's now, they do a great job. And a buddy of mine w/ a pr3 has the stage2's aswell. in my opinion take opion A.(Continue with stage 2s - Dont worry about the 11.0 compressoin because the clearance will NOT be an issue, There will be MORE power still than stage 1s)
Old Mar 20, 2005 | 10:12 AM
JinteDgraM's Avatar
Default Re: Which cam is ideal for my compresison? (b20byJDMotors)
I want to clarify that I will have to mill my JDM b16asir2 0.020 to get 11.0 compression.... and you're saying that with the biggER cam (Stg 2 ) there will stilll be NO clearance probs? For sure? Because honestly I dont have time to clay the engine (Unless its super easy, but I'm unfamiliar with the process)
Brandon
Old Mar 20, 2005 | 10:27 AM
we clayed and it cleared just fine
Old Mar 20, 2005 | 10:46 AM
JinteDgraM's Avatar
cool, any other opinions?
Old Mar 20, 2005 | 02:28 PM
JinteDgraM's Avatar
bump, and what would be the best way to bump the compression, milling or taking out layers of the OEM HG? i really can't afford a mugen/spoon HG.
Old Mar 20, 2005 | 09:06 PM
JinteDgraM's Avatar
bump
SoyMilk
13
Apr 26, 2007 05:47 PM
Fab-Works
Mar 30, 2004 10:10 AM
Joel_MN
13
Sep 11, 2003 08:28 AM
ramz7887
11
Jun 2, 2003 06:57 AM
ramz7887
May 30, 2003 01:24 PM
