Alternator Belt or AC Belt, Need help
Old Mar 20, 2005 | 07:42 AM
oxSLEEPERxo's Avatar
Default Alternator Belt or AC Belt, Need help
If the Alternator Belt or AC belt is too tight, would it squeak? right now my car is squeaking when i start it up. How much deflection should each of the belt have?
Old Mar 20, 2005 | 08:05 AM
urquidezj's Avatar
Default Re: Alternator Belt or AC Belt, Need help (oxSLEEPERxo)
what i did was just tightened it to the point where i can still move the belt with my finger. i did the mistake of super-tightening it and it broke
Old Mar 20, 2005 | 08:08 AM
Lmgrcivic's Avatar
Default Re: Alternator Belt or AC Belt, Need help (urquidezj)
normally when it sqeaks it means its to loose, you want it tight to the point where you can push down on the belt between the 2 pulleys about a 1/4 to a 1/2 in and it should be good it thats the way it is just spray alittle bit of belt dressing on there and it will take the sqeak away.
Old Mar 20, 2005 | 11:23 AM
Default Re: Alternator Belt or AC Belt, Need help (Lmgrcivic)
thanks, i got rid of the squeak
Hill4589
Nov 14, 2008 12:26 PM
Integrity 19
Mar 9, 2005 10:13 AM
speedaholic92
Sep 13, 2003 02:03 PM
Atiyeh
May 30, 2002 03:34 PM
