Leaky Clutch Master Cylinder?
Old Mar 20, 2005 | 06:43 AM
sfr4dr's Avatar
Default Leaky Clutch Master Cylinder?
Anyone ever have this problem? I have to add fluid every few months. It leaks into the cab. The fluid looks pretty murky. Could old fluid contribute to the leaking?
Old Mar 20, 2005 | 07:14 AM
B20TDC2's Avatar
Default Re: Leaky Clutch Master Cylinder? (sfr4dr)
i had the same problem just change the m/c and that will fix it dont forget to bleed the system whenn your done
Old Mar 20, 2005 | 07:15 AM
AlphaQup's Avatar
Search Nextime, since this issue is a commen problem.
You need to replace your CMC. It only cost 30-70 bucks depending on where you buy it. Very simple replacement if your mechanically inclined.
Old Mar 21, 2005 | 02:14 AM
egtwincam's Avatar
yup bad clutch mc.. might as well check your slave if its leaking too...
WillyD
Transmission & Drivetrain
Oct 1, 2011 10:04 PM
duyfash0
Mar 21, 2010 04:08 PM
jajackson
Nov 16, 2007 08:50 AM
OnebadJdmEg6
May 29, 2003 07:41 AM
