si tranny to from dx? flywheel?
Old Mar 19, 2005 | 09:29 PM
CRXalwysk8's Avatar
Default si tranny to from dx? flywheel?
ok right now i have a d15b vtec with a dx tranny. i found a si tranny and want to put it in next week. can i use the same flywheel???
Old Mar 19, 2005 | 10:23 PM
CRseXy's Avatar
Default Re: si tranny to from dx? flywheel? (CRXalwysk8)
YEP! Although I dont know what year the d15b Vtec came in. but if its a 90+ your going to have to use the right clutch. 88 SI transmission uses a smaller clutch and such. a 88 clutch and PP will bolt up to a 89 flywheel, I know cause I have a 89 DX, with a 88 SI trans.
In other words, what year is your SI trans?
Old Mar 19, 2005 | 10:26 PM
sloweredcivic's Avatar
as i recall the 90-91 were slightly larger surface area than the 88-89 so if the years are the same to the clutch you will be fine other wise you can't run a 90-91 clutch on a 88-89 flywheel but don't quote me on that also you need to watch the transmission spline count it may not work with your clutch depending on year the 88 is 21 and 89 and above is 20 i believe good luck to you
Old Mar 19, 2005 | 11:31 PM
ServiceAdvisor's Avatar
Match the Fly and ALL clutch components to the transmission or you will be in for a world of pain. Just take your flywheel to a small auto parts place and tell them its the same year as the trans and buy a new one. You can get it for like $40 since you gave them your core. Then get the clutch combo to match the fly/trans year. 88 only matchs 88, 89 is seperate also. But 90-91 is same. Stick with trans year and you'll be alright - Darrell
Old Mar 20, 2005 | 12:56 PM
CRXalwysk8's Avatar
Default Re: (DOHCZCCRXSi)
i mean... can i use my clutch and flywheel from the dx tranny on the si tranny. the dx tranny is a 91 by the way
Old Mar 20, 2005 | 12:58 PM
EJ2-Fluffy's Avatar
Default Re: (CRXalwysk8)
1988 clutch = 21 spline (200 mm surface)
1989 clutch = 20 spline (200 mm surface)
1990-1991 clutch = 20 spline (212 mm surface)
Use the appropiate clutch for that year flywheel.
-Jon
Old Mar 20, 2005 | 03:22 PM
CRXalwysk8's Avatar
Default Re: (CRX-Fluffy)
lol. thats not what i mean.... i have a 91 dx flywheel and clutch already on the tranny. will this setup work with the si tranny
Old Mar 20, 2005 | 03:33 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRXalwysk8 &raquo;</TD></TR><TR><TD CLASS="quote">lol. thats not what i mean.... i have a 91 dx flywheel and clutch already on the tranny. will this setup work with the si tranny</TD></TR></TABLE>
Yes, 90-91 clutchs are the same part # for all models. I would call an auto-parts store and ask them for the part #s on both the Si and DX flywheels, if they match then you can use either flywheel. Don't just guess and risk it then have to take it apart again. - Darrell
Old Mar 20, 2005 | 03:35 PM
EP3_05's Avatar
All the information you need to know has been posted above. If the Si trans is a 90-91 you will be able to use your existing setup. Otherwise you will need to match the flywheel and clutch to the year of the trans.
Old May 2, 2005 | 06:25 PM
rice is nice's Avatar
Default Re: (91civic)
if you have an 89 transmission, can you just use a 90+ flywheel, and then use a 20 spline 212mm clutch with it?
Old May 2, 2005 | 07:31 PM
bagpipe goatee's Avatar
yes
Old May 2, 2005 | 07:38 PM
SwissChEz82's Avatar
Default Re: (bagpipe goatee)
Anything made between 90 and 00 uses the same size clutch and flywheel combo, I believe its 212mm flywheel with 20 spline input shaft.
Old May 3, 2005 | 06:26 AM
jlicrx's Avatar
the only way it won't work is if the Si transmission happens to be 88
Old May 3, 2005 | 07:18 AM
Default Re: (jlicrx)
Sweet.
Well it should be an 89, cuz it's in my 89 civic si, and it looks have not ben replaced.
dwerpk
Jun 5, 2006 05:09 PM
mr_hahn73
Nov 11, 2005 05:58 PM
kekek-20
11
Jan 4, 2004 01:50 PM
sohcvtec66
Nov 18, 2003 09:49 AM
brent_G
Oct 7, 2003 07:52 PM
