Got some clean passes, 12's
I got some good clean passes last night
I kept turning the boost up everypass. Only like a 1/4 turn with the Turbo XS MBC. I am stoked
I couldn't believe the 116 traps, and my first 1.9 60' These were done on the 215/60/14 BFG Gforce drag radials.
Thanks all. I was at about 14lbs. of boost. Tire pressure was at around 14lbs also. I thought the LS tranny was gonna kill my top end
I ran a couple weeks ago and couldn't break 110 traps
I thought my clutch was going out as I could smell it after ever run. This weekend I changed the rotors and pads. Man my rotors were warped
I am pretty sure they were so warped that it was contacting my pads and slowing me down. I am just glad my car is where I thought it should be
congrats on the new #'s, i do have a question for you. can you please measure the tire height for me, i been trying to get this # but haven't been able to find it on the web. i'm trying to figure out, how the tire height compares to what i have been running. this will give me an idea, on how my gear ratios will be affected by using this tire TIA
The tires are 24.2" tall. I thought I was gonna lose a little mph with them, but apparently not
. I am pretty sure this is the tallest BFG gforce that is made, but not many people use them because of the 14" size. Fit my LS sunflower rims perfectly
Need alittle more practice with them and I know I can cut a 1.8
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97hb »</TD></TR><TR><TD CLASS="quote">The tires are 24.2" tall. I thought I was gonna lose a little mph with them, but apparently not
how high on the rpms, were you leaving the line? i think with practice, you'll be able to hit a 1.8 60'
</TD></TR></TABLE>how high on the rpms, were you leaving the line? i think with practice, you'll be able to hit a 1.8 60'
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97hb »</TD></TR><TR><TD CLASS="quote">Thanks all. I was at about 14lbs. of boost. Tire pressure was at around 14lbs also. I thought the LS tranny was gonna kill my top end
Props on your car, times, and not being skered and cranking the boost up
</TD></TR></TABLE>Props on your car, times, and not being skered and cranking the boost up
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jdm_Rice_Monster »</TD></TR><TR><TD CLASS="quote">
Thanks mang
. When we gonna see the CRX up??? I wanna see that bad boy run.
</TD></TR></TABLE>Thanks mang
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jockobo »</TD></TR><TR><TD CLASS="quote">good to see your getting some better times...i figured you could've done better than the high 12s on opening night
Yeah, that first night at ennis sucked. No ambulance for 2 hours
It also sucks you didn't hit your 11's but it will be here
</TD></TR></TABLE>Yeah, that first night at ennis sucked. No ambulance for 2 hours
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by smokey2.0 »</TD></TR><TR><TD CLASS="quote">
how high on the rpms, were you leaving the line?</TD></TR></TABLE>
can you share that info? TIA
can you share that info? TIA</TD></TR></TABLE>
I was leaving the line about 5k and slipping the clutch. I was tempted to drop the clutch but I don't want any wheel hop. I am going back out this friday and am gonna try some different launches. Anything you recommend??? I am on stock axles, stock diff, and stock shocks w/ 140k on them
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosted2cam »</TD></TR><TR><TD CLASS="quote">nice runs, whats your setup?</TD></TR></TABLE>
https://honda-tech.com/zerothread?id=1007755
well if you know how to slip the clutch, just come up on the rev a little more. but if you get any wheel hop, get off the gas because you'll break something. it also depends on how much boost, you're building at the line! good luck, and keep up updated
</TD></TR></TABLE>well if you know how to slip the clutch, just come up on the rev a little more. but if you get any wheel hop, get off the gas because you'll break something. it also depends on how much boost, you're building at the line! good luck, and keep up updated
Thanks mang
. When we gonna see the CRX up??? I wanna see that bad boy run.</TD></TR></TABLE>
I am hoping to have it done by summer painted and all but i have alot going on right now...........Ill be at the track the first week shes back though
Thanks mang
. When we gonna see the CRX up??? I wanna see that bad boy run.</TD></TR></TABLE>I am hoping to have it done by summer painted and all but i have alot going on right now...........Ill be at the track the first week shes back though
