searched for days......obd0-obd1 swap, dizzy question
Old Mar 19, 2005 | 03:00 PM
Infinite Auto's Avatar
Default searched for days......obd0-obd1 swap, dizzy question
i need to know is will a d16z6 dizzy work with my b20vtec in an crx converting to obd-1????
i now hear that it will be 20 deg off, any way to fix this?
i have one in my garage and it seems to fit decently, probably just cut/modify the "lobe" of the dizzy closest to the vtec solenoid. would that solve my problems and work fine?
i swear ive heard something on this before, and i have been searching for an hour, maybe i just suck lol....thanks in advance
Modified by B18TurboEF at 8:52 PM 3/19/2005
Old Mar 19, 2005 | 03:05 PM
HONDABROMANDUDE's Avatar
Default Re: searched for days......obd0-obd1 swap, dizzy question (B18TurboEF)
It will bolt on and run, but you wont either wont be able to retard the timing far enough or advance it, I cant remember which it is.
Old Mar 19, 2005 | 03:08 PM
Default Re: searched for days......obd0-obd1 swap, dizzy question (HONDABROMANDUDE)
well all im looking for is totally stock timing, all of my timing will be done with my chipped p28 on uberdata
Old Mar 19, 2005 | 03:11 PM
I tried this and If I recall correctly the furthest I could retard the timing was atleast 20 degrees advanced.
Old Mar 19, 2005 | 03:51 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HONDABROMANDUDE &raquo;</TD></TR><TR><TD CLASS="quote">I tried this and If I recall correctly the furthest I could retard the timing was atleast 20 degrees advanced.</TD></TR></TABLE>?????????????????????????????????
Old Mar 19, 2005 | 04:08 PM
Read, its not that hard.
Old Mar 19, 2005 | 04:36 PM
well i guess that came out wrong, i was just putting ?????'s for more info......thanks though lol
Old Mar 19, 2005 | 07:52 PM
up for more info plz.....im sure somebody has a link or sumthin lol.....
Old May 6, 2005 | 12:16 PM
B20fun's Avatar
You can always adjust the spark timing with your engine management however it doesn't adjust your fuel timing. You would need to get it where a stock distributor would be. You might need to make a bracket to get it right.
Swap'DShuttle
18
Sep 13, 2012 06:02 AM
D16SohcVtec
Dec 3, 2008 07:14 AM
ONE.SIX SI
Nov 27, 2004 04:00 PM
rideblitz
Oct 18, 2004 06:30 AM
1tyme
Dec 4, 2002 10:39 AM
