Hi Ho, Hi Ho, It's on to Sears I go for a Lightweight Battery...
Old Jan 24, 2002 | 12:57 PM
01itr518's Avatar
New User
Default Hi Ho, Hi Ho, It's on to Sears I go for a Lightweight Battery...
The only problem is, I don't know which one to go with.
Anyone have any suggestions? I'm just lookin' to reduce some more weight without dropping $300 for a Spoon battery.
Help!!!
Old Jan 24, 2002 | 01:02 PM
Big Phat R's Avatar
Default Re: Hi Ho, Hi Ho, It's on to Sears I go for a Lightweight Battery... (01itr518)
A CRX battery should fit.
norice's Avatar
Don't eat pizza for a few weeks.
The difference in weight between the Spoon and the stock battery is just over 6 lbs. Unless your second name is Kleinubing, I think I would try to find other things to worry about.
Old Jan 24, 2002 | 01:03 PM
B2FiNiTY's Avatar
Your that desperate for weight savings?
Old Jan 24, 2002 | 01:18 PM
Dropspeed's Avatar
Default Re: Hi Ho, Hi Ho, It's on to Sears I go for a Lightweight Battery... (B2FiNiTY)
I just installed my Dyna-Batt from Performance Distributors about 2 weeks ago. It weighs 13.5 pounds, 12volt at 16 amp hours. $155.00 My stock ITR battery weighed 28pds on my certified bathroom scale. It is very swimilar to the Spoon battery in size/weight and output. 7"x3"x6.5"
Mattj
Old Jan 24, 2002 | 01:32 PM
uber_nihilist's Avatar
Default Re: Hi Ho, Hi Ho, It's on to Sears I go for a Lightweight Battery... (norice)
D00dz. Weight savings is...weight savings! Any reduced weight the better, and maybe his old battery p00p00ed out on him. So then why not replace it with one that's lighter when he's gonna do it anyway?
Do a search too, I remember someone was suggesting lawnmower batteries are a good lightweight option a couple of weeks back. They were supposed to work fine.
Old Jan 24, 2002 | 01:36 PM
Bert's Avatar
Default Re: Hi Ho, Hi Ho, It's on to Sears I go for a Lightweight Battery... (natadekoko)
I heard Odyssey batteries were light and cheap... supposedly 8 lbs lighter than a stock ITR battery. If you need a battery anyways why not save a little wieght in the process.
[Modified by Bert, 2:39 PM 1/24/2002]
Old Jan 24, 2002 | 01:38 PM
Big Ed's Avatar
Default Re: Hi Ho, Hi Ho, It's on to Sears I go for a Lightweight Battery... (Dropspeed)
Does Performance Distributers have a website or phone number where I could reach them? Does anyone else carry this battery.
Old Jan 24, 2002 | 01:47 PM
davidnyc's Avatar
Can a lawnmower battery provide enough power to crank a car in winter?
Old Jan 24, 2002 | 01:50 PM
Dropspeed's Avatar
Default Re: Hi Ho, Hi Ho, It's on to Sears I go for a Lightweight Battery... (Big Ed)
The phone #is 901 396 5782, they are in Memphis TN. The website is something like http://www.performancedistributors.com They seem to specialize in Distributors for Ford and GM products.
I left my battery in the stock location becaus I figured by the time I installed the battery in the back of the car, running all of the cable and fabricating a new hold down I would gain back some of the weight I just paid to rid.
Mattj
Old Jan 24, 2002 | 01:58 PM
Default Re: Hi Ho, Hi Ho, It's on to Sears I go for a Lightweight Battery... (davidnyc)
Here is the big battery debate from a while back: https://honda-tech.com/zerothread?id=110801
Old Jan 24, 2002 | 02:04 PM
nsxtcjr's Avatar
New User
You can find out more about Odyssey Batteries on their website.
Old Jan 24, 2002 | 02:06 PM
Cold Chunker's Avatar
Remember, this ain't your daddy's Die-Hard.
Quote....
The new, recently installed Dyna-Batt 12 V has died. The culprit is believed to be the Viper Alarm that drains the battery while the car's engine isn't running.
Race cars generally don't have alarams and radios....so just be sure what you get into. The Dyna-Batt has just 1/3 of the reserve capacity of a typical battery, but it still provides the same CCA.
Just some info....
Old Jan 24, 2002 | 02:15 PM
Dropspeed's Avatar
Default Re: Hi Ho, Hi Ho, It's on to Sears I go for a Lightweight Battery... (Cold Chunker (98ITR461))
I was told flat-out by Perfromance Distributors "not to use the battery without a charging source" ie: don't wash your car and listen to the radio with out it running, it will die.
Mattj
Old Jan 24, 2002 | 02:23 PM
nEoMuGen's Avatar
Well, if your last name is Kleinubing, you don't need a light battery....just bump away!!
Old Jan 24, 2002 | 02:24 PM
Big Ed's Avatar
What a coincidence, neither does mine! Thanks for the info guys.
Old Jan 24, 2002 | 02:28 PM
Jon7's Avatar
I researched the battery issue last summer when my stock battery died. I got a new OEM battery. It was the best value by far and doesn't weigh much either. At most with a lightweight battery, you may save 15 lbs, but you won't have piece of mind that it will always start. Don't waste your time with anything else but a stock replacement. Money can be better spent elsewhere.
Rob.
Honda Fit
Oct 4, 2008 09:13 AM
vti444
Jul 21, 2005 06:10 PM
ILOVEGIRLS
Oct 28, 2002 03:11 PM
redciv
Aug 20, 2002 09:37 AM
Asahi
Jul 26, 2002 09:31 AM
